Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Using the new 2012 Shigaclone to create a killer high end transport
Old 31st March 2013, 12:02 PM   #151
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Can you please tell us a bit more on how are you using the second psu?
Old 31st March 2013, 06:52 PM   #152
pchw is online now pchw  United States
The second PSU is a 5V reg, based on Martin's
Using 3-pin regulators off-piste: part 4
It is for the separate 5V supply. You can see it soldered to one of L4's (removed) pads that is connected to L5. Ground is soldered to neaby ground plane. Another convenient 5V soldering pad is the V4 test point. FWIW, there are 2 9-0-9 transformers in the ATX PS case.
- Fred -
Old 4th April 2013, 07:29 PM   #153
tonyptony is offline tonyptony  United States
For my custom model I'd like to use a power entry connector with a built in switch. The idea is that switch will control the power to the digital circuitry, besically keeping that on all the time. A second switch on the front panel will control power to the mechanism motors and the display. My experience tells me keeping the digital stuff cooking all the time makes for better sound.
What is the feeling on using a power inlet with built in filtering? Something like this
15CUFE1 - TE CONNECTIVITY / CORCOM - POWER ENTRY MODULE, MALE, 15A | Newark
Old 4th April 2013, 10:17 PM   #154
dimkasta's Avatar
I ve been using schafner ones for quite some time with excellent results. The one that has dual everything, including fuses.
FN389B-6-21 Schaffner | Mouser
Old 4th April 2013, 11:00 PM   #155
Mmm, looks nice.
I wonder if using a regular inlet and hanging a really good cap like a Mundorf or V-Cap on the primary side would be better.
Old 24th April 2013, 06:21 PM   #156
Tibi, with respect to my plan of having separate 8V and 5V supplies, does the 8V feed anything besides the mechanism? I'm trying to decide if I want to keep the 8V and 5V powered on all the time, and add a switch for the display only, or add that "run time" switch for the entire 8V feed and display. If the 8V does not power anything on the main PCB that "needs" to be on all the time then I'd make that part of the switch to throw when wanting to play a CD.
Old 24th April 2013, 06:38 PM   #157
tvicol is offline tvicol  Romania
tvicol's Avatar
Using the new 2012 Shigaclone to create a killer high end transport Using the new 2012 Shigaclone to create a killer high end transport
Tony,
8V power directly only LA6541.
Tibi
Vicol Audio
Old 24th April 2013, 11:34 PM   #158
Originally Posted by tvicol View Post
Tony,
Tibi
Thanks Tibi. I guess then it will be okay to keep the 8V feed as separately switched, but I think I will do it at the 8V output of the PS board, and not at the AC input. That way at least the PS will remain at a quiescent operational state.
Old 27th April 2013, 01:49 AM   #159
If I want to keep the buttons active, but cut power to the display, how would I do it?
Old 27th April 2013, 06:36 AM   #160
tvicol's Avatar
Normally if you put a switch on LC78601 pin 40 - Vlcd1. This should allow you to switch on/off internal lcd mux.
tibi
Vicol Audio
Using the new 2012 Shigaclone to create a killer high end transportHide this!Advertise here!
Shigaclone transport Gallery bernhardn Digital Source 17 18th August 2014 03:36 PM
JVC RC-EZ51 for SHIGACLONE High End Player MBA Swap Meet 0 4th March 2012 06:32 AM
WTB: Shigaclone CD transport mgf Swap Meet 1 4th June 2011 03:25 PM
shigaclone transport merlin2069er Swap Meet 3 28th March 2011 03:43 PM
shigaclone cd transport for sale patriz Swap Meet 2 23rd April 2008 01:59 PM
Copyright ©1999-2017 diyAudio
