Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Using the new 2012 Shigaclone to create a killer high end transport
Old 22nd March 2013, 02:50 PM   #141
tvicol is offline tvicol  Romania
tvicol's Avatar
Using the new 2012 Shigaclone to create a killer high end transport Using the new 2012 Shigaclone to create a killer high end transport
Originally Posted by tonyptony View Post
I guess I was confused between this one and what the user in Post #129 did. Did his testing occur before the offering shown in your link?
Tony,
The puck presented here http://www.diyaudio.com/forums/digit...ml#post3416072 was reviewed by customer here http://www.diyaudio.com/forums/digit...ml#post3420613
This is the last CD puck I made and I think that his shape, height and finish is good enough to be compared with the best ones.
As Im a perfectionist, there will be always a better next one.
Hope Im clear now.
Tibi
Vicol Audio
Old 22nd March 2013, 03:48 PM   #142
tonyptony is offline tonyptony  United States
Default PS combination
Tibi, is this power supply combination possible?
Separate +5V feed for the clock
Rest of the PCB fed from the main +8V power supply board
Old 22nd March 2013, 03:55 PM   #143
tvicol's Avatar
Yep. It is possible and very recommended.
Tibi
Vicol Audio
Old 22nd March 2013, 04:14 PM   #144
Jean-Charles is offline Jean-Charles  Canada
Hi Tibi,
Thank you for the very generous offer for the new puck.
I just forwarded you a payment with Paypall as requested, but I could not put a note, this was for the new puck.
So I needed to inform you.
Thank you truly,
Jean-Charles
Old 22nd March 2013, 05:53 PM   #145
Tibi
How would one do this? I looked at the schematic and couldn't see which bead(s) to remove to make a separate +5V for the clock but keep the rest of the voltage feed intact.
Is a separate +5V for the clock significantly better than a +8V feeding the mechanism only, and separate +5V for the rest of the board (including clock)? In all cases the +8V and +5V would be fed by separate transformers.
Old 22nd March 2013, 06:03 PM   #146
Tibi
Old 22nd March 2013, 06:27 PM   #147
tvicol's Avatar
Originally Posted by Jean-Charles View Post
Hi Tibi,
Thank you truly,
Jean-Charles
Thank You, Jean-Charles !
Tibi
Vicol Audio
Old 22nd March 2013, 06:47 PM   #148
tvicol's Avatar
Remove L8 and use L8 PCB pad to feed +5V directly to oscillator can.
Try one by one. First power clock from a separate PS, than feed laser and ASP section with a better PS. Later on you can try also separate 8V for servo and 5V for DSP.
There are other many combinations and is up to you to try them all.
Tibi
Vicol Audio
Old 22nd March 2013, 06:52 PM   #149
Tibi
You're no help!
I'm hoping that for my first attempt, separating out the 8V for the transport/servo and feeding the DSP and clock from the same 5V would be a better solution. I'm thinking getting anything having to do with the servo and motors away from the digital audio circuits is probably the best first step.
Old 31st March 2013, 02:57 AM   #150
pchw is offline pchw  United States
A few tweaks to try out tonight (see the pic):
- Split PS.
- Pucks with different damping.
- Fred -
Using the new 2012 Shigaclone to create a killer high end transportHide this!Advertise here!
Shigaclone transport Gallery bernhardn Digital Source 17 18th August 2014 04:36 PM
JVC RC-EZ51 for SHIGACLONE High End Player MBA Swap Meet 0 4th March 2012 07:32 AM
WTB: Shigaclone CD transport mgf Swap Meet 1 4th June 2011 04:25 PM
shigaclone transport merlin2069er Swap Meet 3 28th March 2011 04:43 PM
shigaclone cd transport for sale patriz Swap Meet 2 23rd April 2008 02:59 PM
Copyright ©1999-2017 diyAudio
