Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Universal hi-end hybrid output stage for DAC
Old 29th July 2012, 03:03 PM   #1
audiodesign is offline audiodesign  Italy
Banned
Send a message via MSN to audiodesign Universal hi-end hybrid output stage for DAC
Default Universal hi-end hybrid output stage for DAC
pcb ready
USB DAC 2 - Hi-Resolution System
It can be used with any balanced output DAC chip like AD1955, PCM179x, ES9018, CS439x, AK439x.
Old 30th July 2012, 01:43 AM   #2
dirkwright is offline dirkwright  United States
dirkwright's Avatar
OK.... passive I/V via some resistors to ground from the grid of each vacuum tube with a mosfet follower on the plate of each tube? How is this high resolution again?
Old 30th July 2012, 04:01 PM   #3
Banned
Passive I/V work very good with new DAC like PCM179x and AD1955 .
The component list with the cost has been published, I hope the kit will reduce the total cost.
Old 30th July 2012, 05:40 PM   #4
Jay is offline Jay  Indonesia
Banned
Wow, I thought I was wrong going in similar direction, or I was just too lucky that it sounded so good. So it is not a bad direction at all. But the resolution really depends on the quality of the power supply. Must be decided by listening test. Shunt, coils...
Old 30th July 2012, 07:39 PM   #5
dirkwright's Avatar
All I meant was that it's been shown that a passive I/V resistor's value strongly affects the distortion performance of current output DACs. The lower the resistor's value, the lower the distortion. So, I don't see passive I/V as being the highest possible resolution, though my own design doesn't have a zero input impedance either, but it's pretty dang low. Anyway, good luck with your project.
Old 1st August 2012, 12:31 AM   #6
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
Originally Posted by audiodesign View Post
pcb ready
Can you tell us more about your preference for the AD1955 over the PCM179X? I have already read the very brief comments given in the DAC comparison chart on your homepage, but I'm hoping you might provide a more in-depth opinion on those two chips.
Old 1st August 2012, 02:34 AM   #7
stephensank is offline stephensank  United States
The feedback loop in an active i/v stage does FAR more damage to the sound that the potentially higher noise floor of using a low value resistor for i/v.
Old 2nd August 2012, 07:07 AM   #8
Banned
The comparison between the DAC chip was carried out with various listening sessions with different people and with different equipment in order to have an objective result and not subjective.
The AD1955 chip is the result most relevant to reality sound.
Old 2nd August 2012, 07:11 AM   #9
Banned
New info has been published about the complete project.
Old 2nd August 2012, 08:03 AM   #10
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Strongly? Has been shown? Can you show figures? Harmonic spectra?
Current output dacs are not all the same. Within limits most can tolerate output voltage without particular rise in distortion. Ime 20-30ohms at the output of 1794 work just fine. No clue about the 1955 though.
Besides, even if there is a minor rise in distortion, it's insignificant in the context of a tube output stage.
Universal hi-end hybrid output stage for DACHide this!Advertise here!
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
Hybrid Amp IC plus only output stage TDA7293 PFT Solid State 1 4th May 2010 01:03 PM
HK 'Deuce front end on G2 drive output stage? GordonW Tubes / Valves 0 9th June 2008 02:22 PM
New Hybrid Output Stage and booster for SE Amp smoking-amp Tubes / Valves 3 20th March 2006 02:24 AM
Hybrid tube front end and transistor output stage Burnedfingers Solid State 6 4th April 2004 11:28 PM
