Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
can you buy real tda1541a anywhere these days?
Old 25th July 2012, 10:40 AM   #1
duderduderini is offline duderduderini  Australia
Default can you buy real tda1541a anywhere these days?
Hi
Does anyone know where one can buy a real tda 1541a? Long shot i know but i notice most tda's are in china now.
thanks
"Better to say nothing and keep them guessing than to speak and remove all doubt."
Old 25th July 2012, 10:42 AM   #2
studiostevus is offline studiostevus  Netherlands
I saw one the other day on an Irish site which I suspected may be original... (not sure though). Use Google to find it, I don't remember the site (something like Don's or so)
Old 25th July 2012, 12:28 PM   #3
marce is offline marce  United Kingdom
Most electronics is based in the east these days (in fact 80%0 so most stuff is now made there.
Old 25th July 2012, 02:27 PM   #4
lcsaszar is offline lcsaszar  Hungary
Dönberg Electronics - but I think they source from China too.
Old 25th July 2012, 02:47 PM   #5
elektroj is offline elektroj  Europe
Originally Posted by duderduderini View Post
Hi
thanks
You have to be more specific, duderduderini.
a) What grade?
b) NEW?
c) NOS?
d) Used?
Old 25th July 2012, 06:34 PM   #6
AudioSan is offline AudioSan  Norway
DAC_IC_Analog Metric - DIY Audio Kit
Old 27th July 2012, 11:21 AM   #7
Shinja is offline Shinja  Japan
you should take it from old cd player
especially if you want genuine crowned grade.
Old 28th July 2012, 08:13 AM   #8
erin is offline erin  Australia
Location: http://www.acmuller.net/con-dao/daodejing.html
If the chip works, it is real.
If it gets hot and no sound comes out it is either fake or defective.
Who cares where it is made. There is too much bs surrounding this chip.
Yes some do sound better than others, but it is far more important to get the board design right, and use a standard chinese made chip made in 2004 than to put an S2 into a badly designed board.
The better board layout/design will sound better any day of the week.
Old 28th July 2012, 09:43 AM   #9
Default What design do yourecommend?
Hi Erin.
I should confess that I am a valve head and would like a valve output stage instead of op amps.. tis a personal preference rather than a trigger for glass vs silicon.
I might buy a qls player which obtains the wav files vis an sd card. it has optical and spdif outs on the case BUT it also has I2S on board which one may utilise.
Given this evil plan of mine.. do you have any designs in mind?
Nick
Old 28th July 2012, 09:56 AM   #10
Agreed, a valve output stage on a dac sounds better. Don't bother with solid state output. A total waste of time.
Qls gives very good sound but is a pita to use. Better off using a pc as a source. Pc can sound as good as qls as long as you get the setup right. I2S is also a pain and will only give good sound if the wires are close and grounding between units is very good, usually it is not. Also your hifi ends up looking like a mad scientists lab. Stick to spdif. Avoid any raindrop-hui dacs like the plague.
can you buy real tda1541a anywhere these days?Hide this!Advertise here!
Is this a real TDA1541A? pop11 Digital Source 580 1st February 2017 12:52 AM
Is this a real TDA1541A? pop11 Digital Source 1 24th August 2006 07:16 AM
