New one from AD AD5780 R2R 18bit - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th July 2012, 03:02 AM   #1
georgehifi's Avatar
Send a message via MSN to georgehifi
Default New one from AD AD5780 R2R 18bit
Any good??
http://www.analog.com/static/importe...ets/AD5780.pdf
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 26th July 2012, 07:44 PM   #2
Shinja is offline Shinja  Japan
they have excellent INL/DNL and noise performance, indeed.
but their THD / SFDR may not be as good as.
I found SFDR/THD spec on AD5781/5791's datasheet.
Spurious Free Dynamic Range:100dB @1 kHz tone, 10 kHz sample rate
Total Harmonic Distortion:97dB @1 kHz tone, 10 kHz sample rate
This is not better than old PCM58P...
These spec may improve with deglitching and so on technics.
Old 26th July 2012, 08:34 PM   #3
jcx is offline jcx  United States
odd test spec - maybe inadequate anti-image filter for 10 KHz sample rate?
for a "1 usec settling" DAC 100-200 KHz should be fine, hard to imagine what dynamic errors would show up 100x below rated settling time
Old 27th July 2012, 02:30 AM   #4
The dac is very clearly an instumentation/industrial purpose chip, hence measured & optimised for a bit different set of specs. Don't think one could say if it would be good or bad for audio without trying it.
If UltraAnalog were still in business, they would likely take this chip & seal it up in epoxy with some peripheral circuits & call it a $200 hybrid dac module.;-)
Old 30th August 2015, 05:04 AM   #5
hollowman's Avatar
Expensive, and not well know (not really "designed") or marketed for the audio industry. (The datasheet or the AD product page make no refs ot audio use).
It is classic single multi/R2R DAC, but it's manuf's, stocked and warranty-backed by a MAJOR semi manufacturer.
Schiit Audio is using it... (no free link for them, just Google the word)
Schiit was partly founded by guys from Theta, so they may have stumbled onto something interesting.
Come one folks, pull out those TDA1541s and PCM63s outta your dinosaur CDPs and swap in a pair of these "new" toys ... and report back below ...
"I got banned from a Hi-Fi forum. And I liked it."
- Luv, Katy "Hollowman" Perry
Old 31st August 2015, 10:09 PM   #6
http://www.diyaudio.com/forums/blogs...-multibit.html
http://www.diyaudio.com/forums/blogs...-dac-chip.html
24-bit R2R DAC using miltiple 16/18/20-bit R2R chips Marek Digital Source 21 1st April 2011 09:05 PM
Fisher AD-864/ AD-813 service manual spooney Digital Source 12 28th February 2010 12:38 AM
WANTED: AD 0211/SQ4 ; AD 0163/T8 for philips MFB vintage anton-sa Swap Meet 3 28th February 2008 03:51 PM
datasheet SM5807 & Sm5818, 18bit output ? Bernhard Digital Source 4 19th November 2004 04:59 PM
R2R dac JBL Digital Source 0 4th September 2003 12:47 AM
Copyright 1999-2017 diyAudio
