Is my cd motor ok? - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th July 2012, 04:02 PM   #1
kolobos is offline kolobos  United Kingdom
Default Is my cd motor ok?
Hi, I am about to replace my CDM 12.4 optical lense and noticed that the drive motor for spinning the cd seems different to other motors driving cds. Basically when i turn it by hand it gets to about 175 degrees and then slips the next 5 degrees by itself like its dropping into a groove or is being pulled by a magnet?
I've not experianced this before, is it normal for the type of drive or could it be that what is causing my cd's not to play rather than the optical lense? other cd drives that i have turn with ease.
The unit is from my NSM Jukebox and any help would be appreciated.
Steve...
Old 20th July 2012, 04:11 PM   #2
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
There are two types of spindle motor I saw in PC CDROM´s: DC motor, with a couple of magnets, a winded rotor and two brush to carry electricity to the rotor, and some other a three phase AC motor who has the magnetized rotor (so no brush) and wired stator, and driven by a dedicated IC. In both cases the motor MUST stop in any way when no power is coming into it.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 20th July 2012, 04:38 PM   #3
Many thanks, it's definately being pulled by a magnet and your info has helped put my mind at rest.
Thank you.
Old 20th July 2012, 05:17 PM   #4
Rest the mind is OK, but never to sleep!!!.
Old 20th July 2012, 06:08 PM   #5
KatieandDad's Avatar
Powerful motors will often exhibit the phenomena that you are seeing as the metal components are attracted towards the magnets.
CD motors, particularly older Pioneer motors did fail regularly. They appeared to work but weren't "agile" enough for the task in hand.
Old 20th July 2012, 07:29 PM   #6
I found several IC 3 phase driver burned fire or shortcircuited or dissimilar output at each phase. But fired wasn't uncommon.
In the age of 24 and 32X, there was a kind of IC contoller, that run on a 3 phase motor, that (I don't know why) the IC lost control of disk speed, and then the disc exploded in several small pieces. It run in about one million turns per second.
BLDC motor upgrade board for CDM9/CDM12 transport or CD player iancanada Digital Source 1 21st July 2015 03:51 PM
Marantz CD-94 spindle motor EIRA Digital Source 9 13th March 2012 05:11 PM
Lambda motor vs. XBL^2 motor vs. any other motor Thinkcat Subwoofers 16 23rd December 2008 06:23 AM
Sphinx Project 9 cd motor not running after laser change muizel Digital Source 26 29th January 2008 08:05 PM
Copyright ©1999-2017 diyAudio
