| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
All the good health.
The problem is this: come from China's such a wonderfulkit , collected - and it works. But there is a nuisance, as soon as the signal source is lost (yusb or coaxial) output a white noise, loud enough to do with it. The feeling that this is not a DAC, and radio. When you turn on without a signal source - the silence, the noise appears only if it has worked and lost the signal source. Who can tell what may be the reason? Elements of all tested prior to installation by denomination - are all ok with them (the Chinese can often make a mess and put the wrong). As an option will suit even the current work is to coax (for yusb sound much worse). PS: sorry for the Google Translator |
#2 |
Hi XPOH, I understand what your saying. A bad CS8416 will make odd noises. I had that in CS4398 dac. Replaced the CS8416 and the noise is gone. Look for solder splashes around the CS8416 also. White noise is what I had also. Good luck.
Possible ESD (electrostatic discharge damage) during soldering is the likely cause....
#3 |
Thank you for your response. I will try to
| DAC: CS4398 with CS8416+CM102s | SoNic_real_one | Digital Line Level | 36 | 10th November 2012 09:35 PM |
| CS8416 CS4398 kit issue. | F1 FAN | Digital Source | 4 | 27th November 2011 04:09 PM |
| Crystal CS4398 *2 CS8416 Parallel DAC | LucasAdamson | Digital Line Level | 23 | 16th September 2011 05:51 AM |
| Gigaworks CS4398 CS8416 USB DAC | wushuliu | Swap Meet | 3 | 31st May 2011 07:58 PM |
| DAC using CS8416 and CS4398 | binspaul | Digital Source | 1 | 29th September 2009 11:37 AM |
