Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
shield ic chip at analog ground or digital ground?
Old 17th July 2012, 03:45 AM   #1
KevinLee is offline KevinLee  Canada
Default shield ic chip at analog ground or digital ground?
Hello,
I am going to shield a few ic in my Quad 99 CDP with conductive copper and conductive aluminum tape.
If an IC has both an analog ground and a digital ground, which one should i connect the shield to?
One chip for example is a Cirrus CS4396.
Kevin
Old 17th July 2012, 06:36 AM   #2
Mooly's Avatar
It probably won't make much difference in practice. (Both adding foil and where connected.)
Another slant is that the foils will (could ) pick up noise and inject it into the grounds. It works both ways although the effect would be microscopic I'm sure..
Perhaps connect the foils back to some main PSU ground (or the case) via isolating resistors of say 10 ohm...
Old 17th July 2012, 12:15 PM   #3
marce is offline marce  United Kingdom
Dont bother untill you have read Henry Ott, Electromagnetic compatability engineering, then you will realise that it aint gonna do much.Shielding is an art itself, and if you have any holes or slots its a waste of time. If you look at the cans on PCB's for shielding, they have a contigous soldered join at the bottom where the ground is exposed to create a 360 degree join, you will not achieve this with foil or tape and as Mooly said may cause more noise by creating unintentional dipoles. Adding tails to some remote location is the worse thing you can do with a shield, they have to be connected at source and all the way around the shield. As the digital ground (if seperate ) will tend to be more imune to noise than analogue use the digital ground if you must play.
shield ic chip at analog ground or digital ground?Hide this!Advertise here!
Preamp Umbilical - Use Shield as Ground Lead? Magz Tubes / Valves 16 9th May 2011 04:33 PM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
Ground shield connections question rtarbell Solid State 4 3rd September 2006 09:12 AM
Chassis Ground = Circuit Ground --> Problems? rhildenbrand Pass Labs 5 23rd April 2004 01:08 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
