Rebuilding the original clock circuit (Novice needs help!) - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th July 2012, 09:26 PM   #1
Default Rebuilding the original clock circuit (Novice needs help!)
I was upgrading to a low jitter clock in my CD player, but I screwed up and fried something on the new clock board. I now want to simply reinstall the old oscillator, which had a resistor in parallel and an SMD capacitor to ground on either side. I still have the resister and oscillator but I need to replace the caps. The technical manual does not list their capacitance. Any idea what size caps I could put in their stead?
Old 10th July 2012, 04:44 AM   #2
amc184 is offline amc184  New Zealand
amc184's Avatar
They could have been anything from 10 to about 100pF. I'd try a value of 33pF as a starting point.
Inside Classic Audio, my blog on repairs, modifications and anything else to do with audio.
Old 10th July 2012, 07:48 AM   #3
UV101 is offline UV101  England
UV101's Avatar
What player is it?
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 12th July 2012, 02:51 AM   #4
Thanks for the help. I was advised to use 20 pF and that did the trick. It's a Rotel RCD-955AX
Old 12th July 2012, 09:42 PM   #5
UV101's Avatar
The originals were 47pF by the looks of things
http://www.bwgroupsupport.com/downlo...D-955AX-TM.pdf
where to find original aleph circuit diagram? space2000 Pass Labs 0 19th June 2008 10:50 PM
Original Dynaco 70 circuit mods/upgrades? kegger Tubes / Valves 25 18th February 2007 09:27 PM
help with clock circuit pho_boi Digital Source 10 7th November 2006 12:20 PM
Clock Oscillator circuit argonrepublic Analog Line Level 5 30th January 2006 02:48 AM
original gaincard circuit skyraider Solid State 1 23rd January 2004 10:18 PM
Copyright ©1999-2017 diyAudio
