Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th July 2012, 10:26 PM   #1
tkgafs is offline tkgafs  Scotland
Default Beginners help Needed adding spdif input
Hello,
as a complete beginner could some let me know if the folowing is possible.
I have a broken philips LX3000D home cinema system, the audio section works fine but the dvd player no longer plays discs.
I was wondering if it is possible to add an spdif coaxial input to this system so I can use it as surround sound system in a spare room.
From what I work out the system has an ES6018 Vibratto chip which feeds a CS4360 Dac
the ES6018 pin outs include the following
TWS Pin 32 O Audio transmit frame sync.
SEL_PLL2 I System and DSCK output clock frequency selection is made at the rising edge of
RESET#. The matrix below lists the available clock frequencies and their respective
PLL bit settings.
TSD0 Pin 33 O Audio transmit serial data port 0.
SEL_PLL0 I Refer to the description and matrix for SEL_PLL2 pin 32.
TSD1 Pin 36 O Audio transmit serial data port 1.
SEL_PLL1 I Refer to the description and matrix for SEL_PLL2 pin 32.
TSD[2] 37 O Audio transmit serial data output 2.
TSD[3] 38 O Audio transmit serial data output 3.
these pins the feed something called RA8 which seems to a set of resistors I think
the philips manual says RA8 is a RES Array 4X33R 1/10w 5%
the other side of RA8 then feeds IC10 which is the cs4360 chip
the pins on the cs4360 chip are as follows
Pin1 VLS
Pin2 SDIN1
Pin3 SDIN2
Pin4 SDIN3
Pin5 SCLK
Pin6 LRCK
Pin7 MCLK
I think the connections are as follows
ES6018 > RA8 > CS4360
Pin32 -> RA8 -> Pin6
Pin33 -> RA8 -> Pin2
Pin36 -> RA8 -> Pin3
Pin37 -> RA8 -> Pin4
Would be possible (although very difficult as they are very small !!) to solder a co-axial connection to the input side of RA8 so that I could attach the spdif co-axial output from a satallite tv box to this unit to use its surround sound capabilities which are currently going to waste, and if so which of the connections should I use.
I have the service manual for the lx3000d and the datasheets for the es6018 and cs4360 chips if they would be any help I can extract the relevant sections.
As I said I'm a complete novice so my whole idea might be ridiculous, if so just say so and I'll forget it, but if its possible even if its no where near where I think it can be done please suggest a method which would be possible.
best wishes
Tkgafs
SPDIF S/P-DIF DOBM resp. Digital Input Selector include USB-SPDIF Converter tiefbassuebertr Digital Source 6 21st February 2012 08:00 PM
IC with SPDIF input to USB or 1394 (or with HDMI input for audio stream) VickHard Digital Source 2 26th March 2010 02:17 AM
Adding SPDIF input port to Sony DAV-DZ100 i-dar Digital Source 0 25th January 2010 07:21 AM
Adding SPDIF out to Synth w/only Analog Out electromusician Digital Source 7 6th April 2005 11:30 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
