Problems with DCX2496 setup - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th July 2012, 02:52 PM   #1
Default Problems with DCX2496 setup
I did a fair amount of searching and was not able to resolve my issue so I thought that I would post and hope someone could help me out. I recently got a Behringer DCX2496. My setup consists of an inexpensive Pyramid pre-amp to DCX2496 (with RCA to XLR male), from DCX2496 to two small Lepai amps (with XLR female to RCA). I am attempting to use 1, 2, 3, 4 as LH, LH for the purposes of testing to establish a crossover point. Here is the issue; I am only getting sound out of one side - the left side. Is there something wrong with my setup? Is the XLR to RCA an issue? Any thoughts/help would be greatly appreciated. Thanks.
Old 4th July 2012, 03:01 PM   #2
Pano is offline Pano  United States
Pano's Avatar
Of course it could be a cable problem, swap them to see.
Or it could be routing. Look to see how inputs A&B are routed. Do they go to the output channels you want?
Old 4th July 2012, 03:10 PM   #3
First check if anything is muted (red leds), then check cable, then routing, and levels
It's a complicated tool, so a little patience is needed.
Old 4th July 2012, 03:19 PM   #4
Pano's Avatar
Ah, of course! The mute buttons. Yes, check those first.
Old 4th July 2012, 04:13 PM   #5
I did the simple thing and checked the cables. I jiggled one of them that was connected to a Lepai amp and 'BAM' - there was sound. I was thinking more critically - something wrong with the setup or ??. Thanks for your responses. This thing is way cool.
Old 5th July 2012, 04:30 AM   #6
Pano's Avatar
Glad you found it! Yes, cables and connections seem to make up 90% of audio problems.
MiniDSP vs DCX2496 vs DCX2496-Modded vs DEQX gainphile miniDSP 20 14th September 2011 10:24 AM
MiniWatt N3 problems, oscillation thumping and RF/motor problems. Destroyer OS Tubes / Valves 18 6th July 2010 01:14 AM
Is this all I need for the DCX2496 ? Will Digital Source 17 25th November 2007 08:30 AM
Problems with HT speaker setup Vivek Multi-Way 16 18th April 2006 07:08 AM
DCX2496 connectivity problems MtBiker Digital Line Level 0 15th June 2005 03:51 AM
Copyright 1999-2017 diyAudio
