Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th October 2003, 02:59 PM   #1
ManUtd is offline ManUtd  Norway
ManUtd's Avatar
Default Cs8412
Is there any 100% compatible transceivers to thisone?
It is inside a DAC and i want to upgrade it.
Any good suggest
ManUtd.
Old 15th October 2003, 03:00 PM   #2
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
cs8414 is totally compatible if you have a soic -> dip adapter.
Brian
Old 15th October 2003, 03:09 PM   #3
OliverD is offline OliverD  Germany
OliverD's Avatar
What is your intention?
Upgrading sound quality? Then a change of the receiver chip alone won't help. Changing the frontend to a ASRC fed from a local low-jitter clock can improve things as well as reclocking near the DAC chips.
If all you need is 96/24 compatibility, the CS8414 will work as a pin-compatible replacement, and, depending on the application (schematic?), if you're lucky you won't have to modify anything else.
Old 15th October 2003, 03:20 PM   #4
Electrons are yellow and more is better!
peranders's Avatar
8412 and 8414 isn't 100% compatible, the LED's are changed (maybe something else) but otherwise it's similar.
If you mainly have 44.1/16 signals this change to 8414 won't be a big upgrade.
/Per-Anders (my first name) or P-A as my friends call me
Old 15th October 2003, 03:53 PM   #5
ManUtd's Avatar
My intension is only to replace a CS8412 inside a DAC,but i can not find a 8412 at Crystal Inc only 8414.
ManUtd.
Old 15th October 2003, 04:19 PM   #6
peranders's Avatar
Which reciever do you have right now?
Old 15th October 2003, 04:57 PM   #7
ManUtd's Avatar
I have CS8412 inside a DAC from AudioSynthesis called DSM.
Old 15th October 2003, 07:43 PM   #8
peranders's Avatar
They main difference between the recievers is that the 8414 can take 96 kSp so if you don't have any 96 kSp material this won't be a great upgrade.
Old 15th October 2003, 07:47 PM   #9
ManUtd's Avatar
Only reason for this change is i can`t find any CS8412.
ManUtd
Old 15th October 2003, 07:54 PM   #10
A'af is offline A'af  Indonesia
A'af's Avatar
What do you mean manutd, upgrade with the same chip doesn't result anything, if you wanna make difference try give that chip a better power supply and wanna make a little extereme, power your DAC with battery, make a big leap change.
why cs8412? SunRa Digital Source 2 24th November 2006 06:36 AM
Anyone have CS8412? bezobraznia Digital Source 16 15th December 2005 09:08 AM
Cs8412 burbeck Parts 1 25th February 2005 10:06 AM
Fs: Cs8412 mdlover Swap Meet 0 26th January 2005 04:10 PM
Help with Cs8412 NickC Digital Source 0 6th January 2004 11:11 PM
Page generated in 0.10390 seconds (79.75% PHP - 20.25% MySQL) with 10 queries
