Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
How to connect WM8804 and CS8412
Old 23rd June 2012, 02:23 PM   #1
Itco is offline Itco  Bulgaria
Send a message via Yahoo to Itco How to connect WM8804 and CS8412
Default How to connect WM8804 and CS8412
Hi, i have SM5842 and 2xPCM58P-K.
View image: 100 4890
I wan to make SPDIF DAC with them, and for SPDIF receiver i think to use WM8804. But i am not sure how to connect WM8804 with SM5842. SM5842 support Left Justified input format. But WM8804 output format is "Left Justified with flags". What mean this "flags", and is this format will work proper? I'll appreciate any help to solve that problem.
Old 23rd June 2012, 07:23 PM   #2
s3tup is offline s3tup
s3tup's Avatar
SM supports LJ and RJ, check page 17 of http://www.dddac.de/files/SM5842.pdf
It has "TTL compatible" inputs/outputs, but their trip voltage is somehow high at 2.5v. WM may work here.
The "flags" thing shouldn't puzzle you, as SM will ignore everything that comes after LSB.
The missing link between lead and gold in alchemist's world was BS and commerce.
Old 24th June 2012, 10:29 AM   #3
Thank you very much for help. When this flags is not a problem, I'll make the schematic and configure pins of SM5842 to accept LJ. After that I'll post the schematic to take a look, is it correct.
Old 24th June 2012, 03:17 PM   #4
Now I look the page 3 http://www.dddac.de/files/SM5842.pdf. If I understand correct, to accept left justified format I must have to make INF1N HIGH and DI/INF2N LOW, the input data being now IW1N/DIL and IW2N/DIR. Is it right this pin configuration? I am not sure is it Left Justified format=LR alternating, leading data?
Old 24th June 2012, 04:43 PM   #5
s3tup's Avatar
You are right,
Page 17, fig. 5 on SM's DS shows us the signal timings.
The data is close to the left, and comes simultaneously with LRCLK = LJ.
I2S format would be the same, but with data channel delayed by 1bclk after the lrclk change.
WM's datasheet shows the same timings at page 48, fig. 23.
http://www.qobuz.com/info/IMG/pdf/wm8804.pdf
It appears the SM needs it's DIR/DIL pins connected together to properly load channel interleaved LJ, as it takes L_CH from DIL and R_CH from DIR.
Old 25th June 2012, 05:48 PM   #6
Thank you for explanation. I made the schematic, and configure the SM5842. Can you take a look, for errors in my schematic.
I'm little confused. On page 3, the table of pin 4. "LR alternating, leading data" is configured with INF1N-HIGH and DI/INF2N-LOW. But the figure5 on page 17 says that INF1N=INF2N=HIGH?
http://postimage.org/image/xe9togext/
How to connect WM8804 and CS8412Hide this!Advertise here!
Some questions about the WM8804 tessier Digital Line Level 4 20th February 2011 05:52 PM
WTB Wolfson WM8804 dsavitsk Swap Meet 0 6th May 2010 02:02 AM
How connect CS8412 to OS filter ? Bernhard Digital Source 11 22nd December 2009 11:42 PM
WM8804 Software Control fmak Digital Source 9 2nd January 2009 03:14 PM
Source for WM8804/5? error401 Digital Source 4 12th May 2008 03:43 PM
Copyright ©1999-2017 diyAudio
