Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Are clocks always can shaped?
Old 23rd June 2012, 07:06 AM   #1
jackyno7 is offline jackyno7
Default Are clocks always can shaped?
Opened up my new ONKYO cd player to have a looksy, and cannot see a tin can shaped item anywhere?
Old 23rd June 2012, 07:26 AM   #2
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
I presume you are looking for a crystal.
Not all CD players use crystal based oscillators, some use simple RC oscillators or ceramic resonators.
Old 23rd June 2012, 11:06 AM   #3
hmm.. specification I just looked up claims it has a crystal oscillator.. pcb's don't appear to be double sided.. Though I still wonder if it is on the reverse..
There's a strange looking IC with a metal square exposed.. not sure what that is..
Old 23rd June 2012, 12:46 PM   #4
DF96 is offline DF96  England
Microprocessor?
Most packaged crystal oscillators will be can shaped. Most individual crystals in the MHz region will be in smaller cans, but who knows what the electronic packaging industry will come up with next? It is possible that the crystal is inside a plastic package, perhaps looking a bit like a fat IC or a small relay.
Old 23rd June 2012, 12:58 PM   #5
Crystals will usually be in hermetically sealed tin cans. Not necessarilly cylindrical.
It's conceivable that they have used an oscillator module. These are genrally about 10 x 5mm steel cans with the frequency printed on the top.
Old 23rd June 2012, 12:59 PM   #6
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
The crystal may be within an oscillator module.
Frank
Old 23rd June 2012, 04:11 PM   #7
poynton is offline poynton  United Kingdom
poynton's Avatar
Post a photo(s) of the board.....
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 23rd June 2012, 05:51 PM   #8
PlasticIsGood is offline PlasticIsGood  United Kingdom
PlasticIsGood's Avatar
No metal can here either. I guess the oblong plastic package towards the bottom left of this poor photo is a ceramic resonator. It has a xtal symbol printed next to it on the very informative Elna board. Unfortunately I haven't found a cheap manual for this Kenwood DP770.
Where the Sony 20152 datasheet shows a crystal, the Kenwood has a transistor, which I assume is buffering the signal from the resonator.
The generation and transimission of clock signals seems to me a dark art. What's the advantage of a quartz crystal over a ceramic resonator? Could it be worth modifying the circuit to accept a crystal?
Old 23rd June 2012, 06:13 PM   #9
Quartz has much higher Q so, other things being equal, it would give much narrower noise bandwidth. I don't know to what extent this is an advantage in audio clocks, as other things might not be equal. It is conceivable that a good ceramic might be better in some respects than cheap quartz, but I don't know. The circuit design matters too. Quartz is likely to have better long-term stability, but this doesn't matter for audio.
It is possible the ceramic resonator is simply a cost-cutter, judged to be good enough by the manufacturer.
Old 24th June 2012, 02:26 AM   #10
stephensank is offline stephensank  United States
The blue plastic ceramic resonator is pretty darn certainly just the syscon clock, i.e., for the controller u-processor. The dsp clock is not apparent in the photo, but must be there somewhere. With a player old enough to use the CX20152(i.e., 1984-85), the crystal positively will be a metal can of a common sort, and definitely not a ceramic-cased SMD xtal nor a large rectangular 4-pin clock module.
Are clocks always can shaped?Hide this!Advertise here!
Clocks szjyec Vendor's Bazaar 0 20th March 2010 01:56 AM
Soundcard clocks planarboy Digital Source 7 7th April 2008 03:58 PM
Audio Clocks quiller Digital Source 12 2nd January 2008 02:28 AM
Relationship between master clocks, system clocks, and audio freqs Garbz Digital Source 10 14th March 2006 02:02 PM
Clocks hacknet Digital Source 9 21st June 2004 08:52 AM
Copyright ©1999-2017 diyAudio
