Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd June 2012, 08:00 AM   #1
Default DIFFERENTIAL FROM DAC TO SPEAKERS
I am about to try a fully balanced configuration from dual differential dacs (two 1541a but not dac / channel) via a pair of Sowter 9545 transformers and pair of LM4780 chipamps (dual LM3886 in one package) as per the attached sketch. (sorry for the quality)
The Dac offsetis rendered irrelevant by connecting the primary as shown but I cannot avoid the IV resistors due to the DAC output only sourcing current not sinking and sourcing it as it would do if the current varied about 0v.
I only need a small volume adjustment so intend to vary the amp gain a little.
Comments?
IanB
PS I've been using it for 12months but with the secondaries in series and connected to a Quad 34/405 and the sound is superior to a Musical Fidelty Xray+ Xdac. (the TDA1541s are run NOS mode)
Old 24th June 2012, 05:02 AM   #2
seems like you're on the right, high end minimalist approach track.... there are silver-wound, multi-tapped transformers used in high end preamps...
Boky
Another TDA1541A based dac (dual differential) Tazzz Digital Source 64 11th May 2013 09:46 AM
Discrete Dual Differential DAC? dantwomey Digital Source 18 5th March 2011 06:24 AM
Differential TDA1543 based NOS DAC dsavitsk Digital Line Level 0 6th April 2009 06:41 PM
Direct WM8816 to differential current output DAC panson_hk Chip Amps 4 27th June 2007 05:03 AM
DAC in Dual Differential mode - schematic? spavleski Digital Source 13 25th September 2005 04:09 PM
Copyright ©1999-2013 diyAudio
