Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th October 2003, 06:41 PM   #1
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Default cdpro2 using pic18f452 for control
Managed to get the cdpro2 module working with a PIC18F452, and playing music with the built-in dac today. Next up is to get the pcb made for this project. I will be using the pcm1792/4 along with the ad1896a. I am prototyping it now.
Overview of testing setup:
Brian
Old 13th October 2003, 06:42 PM   #2
BrianGT's Avatar
closeup. Power supply on the left, regulating both 5v and 9v for the transport. Below the regulators is an inverting opamp with a little bit of gain to get some music playing out of the speakers.
Brian
Old 13th October 2003, 06:46 PM   #3
BrianGT's Avatar
Here is a closeup of the lcd that I am using, an Optrex 20x2 blue C505 one, identical to the ones used in the Apox kits.
Brian
Old 13th October 2003, 06:46 PM   #4
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
looks good. how does it sound so far just as all stock stuff?
Old 13th October 2003, 06:47 PM   #5
BrianGT's Avatar
Here is a closeup of the transport, showing the power going in from the regulators, and then the audio coming out from the built-in dac on the other side. Once I get the prototype dac finished, I will use the i2s interface instead.
Brian
Old 13th October 2003, 06:51 PM   #6
BrianGT's Avatar
Current regulators used, both LM317T adjustable (had them on hand). They are being fed a couple of volts above what the are regulating to, so they are running nice and cool. I haven't decided what to use for the regulation on the final prototype, but this is working fine now. Any suggestions for the power supply for +5 and +9?
Brian
Old 13th October 2003, 06:53 PM   #7
BrianGT's Avatar
Here is a picture of the PIC microcontroller board that I am currently using. It utilizes the PIC18F452, and I added 5 buttons for testing for now (will show other buttons later). They are all tied into a single ADC pin on the PIC, so they can be extended to a lot more buttons easily, while still taking one pin.
Brian
Old 13th October 2003, 06:58 PM   #8
BrianGT's Avatar
heh.. I haven't gotten to the point of listening to it in a detailed manner. If you look at the first picture, you will see one of the 2 speakers used for listening to it... they are cheap speakers the I cut up to wire into my opamp output stage. I don't expect much from the built-in dac, since I am using an external dac, fed by i2s from the transport. Now, it plays music, and the control buttons work, allowing you to pause, stop, play, and change tracks. The lcd displays the current time and track correctly.
I expect it to be a while until I can listen to it in a final prototype form. For the dac now, I am just verifying that it works as wired on a protoboard. I won't give it a detailed listening until I get the pcb done.
Here are the chips that I have been playing around with for the dac, I think that I have settled on the pcm1792, along with the AD1896a for now. I probably will switch to the TI SRC4192 once I am able to obtain some of them. I should be posting details on the digital side of the dac once I finish getting the schematic worked out.
Brian
Old 13th October 2003, 07:06 PM   #9
Banned
every picture you put on i grab and put up on my gallery page : O )
Got more..
ill give you access to my gallery to put some more or LOTS more up on.
Old 13th October 2003, 07:06 PM   #10
BrianGT's Avatar
Here is what I am going to use for the buttons (I will have them set into my aluminum front panel. I think that they will work fine for now. I haven't been able to find anything else that I like. I just have the bottom 9 buttons wired up now, and haven't decided if I want the "direct access" buttons on the transport.
They are taken from an old Luxman D-112 player.
Brian
Trying to program a PIC18F452 in circuit 12 Cents Digital Source 0 13th August 2006 11:32 AM
DSA protocol for CDPRO2 billr Digital Source 3 4th April 2005 09:17 AM
philips CDPRO2 Joules Digital Source 4 12th January 2005 08:06 PM
CDPRO2- do you just add PS? lgreen Digital Source 7 24th February 2004 09:48 AM
EIJ on CDPRO2 DonJuan Digital Source 8 17th February 2004 04:09 AM
Page generated in 0.11071 seconds (84.52% PHP - 15.48% MySQL) with 11 queries
