Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Could this be laser or solider issue?
Old 9th June 2012, 04:22 PM   #1
HiFiGuy528 is offline HiFiGuy528  United States
HiFiGuy528's Avatar
Default Could this be laser or solder issue?
My Sony CDP-XA7es plays fine when cold. Zero issues with tracking all the way to track 39 at the end of a disc. However, once it's warmed up about an hour, it will stop playing completely. The disc will stop and the TOC is gone. To reset this, I have to Eject the disc. It will then play again immediately for about a minute and then the same issue repeats. I hate to throw it out because it's like new condition. Is this really a laser failure or could this be something else? Thanks for your help.
**** Update ****
Stephensank was so kind to provide me some info and offer help with this player. I am still running some tests to ensure I provide the most accurate information to him and you guys.
I just played through a 55 minute CD-R on the player without an issues. I will do more playback tests to see how long it takes for the player to fail. Any other ideas on what may cause this is greatly appreciated. Thank you!
Old 9th June 2012, 04:59 PM   #2
Conrad Hoffman is offline Conrad Hoffman  United States
I've had some bizarre issues with heat build up and wire flexibility on a different player. Be sure to go in and wiggle stuff to be sure you don't have some intermittent connection. A careful application of freeze mist might localize the problem.
I may be barking up the wrong tree, but at least I'm barking!
Old 9th June 2012, 05:51 PM   #3
HiFiGuy528's Avatar
the sad part is I don't know jack about fixing things or even know where to spray the freeze mist. Everyone tech I spoke to tells me it's the laser. I guess deep inside I don't want to believe it.
Old 9th June 2012, 08:32 PM   #4
stephensank is offline stephensank  United States
It's absolutlely NOT a bad laser, going by your description, and I have been in cd servicing since 1983. It is, however, a pretty odd problem, particularly as it will play for a minute after open-close while still warm. It's the kind of thing that I know someone like me could track down & fix, but would have to have the unit in front of me. It could be as simple as a cold solder joint or two on a cable that gets slightly flexed during load cycle, or could be much more obscure.
Old 9th June 2012, 08:51 PM   #5
HiFiGuy528's Avatar
Where are you located? How much for you to take a look?
Old 10th June 2012, 12:56 AM   #6
PlasticIsGood is offline PlasticIsGood  United Kingdom
PlasticIsGood's Avatar
There may be trip circuits that set and reset parts of the machine in complicated ways.
The fact that the machine works again for a minute after a reload could be that the a trip circuit is discharged on reset, and then it takes that time for the fault to charge it up again.
Could be as simple as a dragging slide. This is a fixed-head Sony AFAIK, where all the gubbins come out with the drawer, so possibly a tripped radial error circuit is reset to enable the drawer to open.
Something goes wrong when it's warm. Not much to go on. My limited experience is that nearly all diagnoses of a bad laser are false.
Being an ES it is probably heroically engineered and worth saving. Someone with particular experience of these machines may be able to recognise the fault immediately.
Old 10th June 2012, 01:43 AM   #7
HiFiGuy528's Avatar
http://www.youtube.com/watch?v=R6TzvFVP8uk
Old 10th June 2012, 03:02 AM   #8
The XA7 has no 'trip circuits' or any other such fault sensing circuits of the nature you are describing. Having now looked through the service manual, I feel it most likely a connection fault between the main servo board & the spindle motor, which does involve flexible circuit-tape that it flexed in load/unload. The OP and I have been in touch by email about the unit.
Old 10th June 2012, 06:08 AM   #9
OK. Knowledge trumps logic. Thanks for letting me know.
The one minute between failures is harder to explain in that case. I would expect it to depend on how long the drawer is open.
I just fixed a mini Sony with the exact opposite problem: until hot it wouldn't play after an eject. After switching on and off it was OK for about a minute. I was just lucky, but I suspect that a leaking cap lowered the threshold at which the drawer-motor current tripped out the power supply to the laser sled motor, until the cap managed to heal itself. Nearly every chip could be disabled by several switches triggered by several events. I very nearly gave up.
Bigger Sonys are simpler, from what I have seen. Good luck.
Old 10th June 2012, 08:22 AM   #10
HiFiGuy528's Avatar
I just finished playing two full length CDs and the unit only stopped once. I had to eject the disc and then Play again and it continued to play through for another 30 min without any issues. Weird...
Humans make Music,
Music makes Miracles.
Could this be laser or solider issue?Hide this!Advertise here!
laser Tool jerryo Multi-Way 0 23rd November 2011 08:32 AM
What laser is this, please ? mschwilson Digital Source 0 29th July 2010 05:17 PM
Laser Instead of an Accelerometer? Is it possible ? jsa_ind Multi-Way 53 20th December 2009 10:55 PM
CDM1 laser FaZ72 Digital Source 10 23rd October 2006 01:35 AM
Laser Engraved bjackson Multi-Way 4 6th March 2005 05:00 PM
