High quality nonos PC based DAC - Page 6 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd April 2008, 11:46 PM   #51
peufeu is offline peufeu  France
> Do you know if the pcm1794A is perfectly compatible with the AL1402G chip in terms of PCM format and timing ?
No idea ! épluchage de datasheet...
> Also does the clocking solution from the DAC side to the RMEhdsp9652 clock
> input break the ground isolation between RME soundcard and outside DAC ?
- isolation transformer (ethernet, pulse, etc)
- fast opto
- or feed it an ADAT signal with no data, needs an ADAT encoder, add an ADC, then you can feed vinyl through brutefir
Old 25th April 2008, 09:44 AM   #52
I use optical-out from Terratec Aureon fun, it is not good, strong distortion.
how is the quality of a chip-based volume control VS normal stepped attenuator? jarthel Parts 4 16th July 2007 02:40 PM
Low wattage, high efficiency, high quality? Nordic Multi-Way 5 4th September 2005 11:12 PM
High Power High Quality Digital Amp aspycaudio Digital Source 0 6th December 2003 09:49 AM
Progression nonos dac&high output fedde Digital Source 3 1st February 2003 12:15 PM
Copyright ©1999-2017 diyAudio
