Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
WEILIANG DAC5 - WM8741 & Tenor TE7022
Old 30th July 2012, 12:06 AM   #71
bcmbob is offline bcmbob  United States
Hi repeet,
No I don't have that yet.I was under the understanding it was an add-on. Is that necessary for USB to function?
I did try the optical input but didn't get any response with the switch in either position.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 30th July 2012, 12:27 AM   #72
repeet is offline repeet  Australia
Absolutely, that is the USB chip.
Old 30th July 2012, 12:46 AM   #73
Regarding the crystal, I'm not sure if it matters either although the screen print on the board seems to indicate it does (one corner is square). Mine is mounted with the printing like this.
Old 30th July 2012, 12:52 AM   #74
kevinkr's Avatar
Is it a crystal or an oscillator? The package used is common to oscillators I've seen/used and if it is in fact an oscillator the orientation is important as there will be a power, gnd and output pin and usually one open pin - obviously there can be only one correct orientation in such a case.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 30th July 2012, 02:01 AM   #75
Sorry, yes it's an oscillator. Anyway the photo above shows the correct orientation.
Old 30th July 2012, 05:01 AM   #76
dhalbakken is offline dhalbakken  Thailand
Here is a photo that shows the square corner of the TCXO and its correct orientation to the lower left in this view.
Old 30th July 2012, 10:47 PM   #77
I have a different brand oscillator but the square corners do match up. This one has four leads and no markings. The second photo shows bottom side connections. Also - there are five pins soldered on the WM8805. Does that correspond to the other builds?
Does the small diode appear to be in the correct orientation? It was difficult to determine and I selected the black end as the mark.
Bob M.
Old 30th July 2012, 11:15 PM   #78
On the circuit diagram pins 22 - 28 of the WM8805 are tied to ground, so that looks ok (however you are only indicating pins 23 - 27). Diode and oscillator look correct.
Old 31st July 2012, 09:34 PM   #79
slider2828 is offline slider2828
Sorry to hear you are having so much problems with this thing :'(
Old 31st July 2012, 11:58 PM   #80
repeet,
I can see the 22-28 pins you mention on the diagram, but a close look at the chip shows what appears to be a different pad (blue arrow)
Green = ground.
Still think I should tie it in?
Bob M.
WEILIANG DAC5 - WM8741 & Tenor TE7022Hide this!Advertise here!
Info on Tenor TE7022? chaparK Digital Source 23 1st January 2016 01:46 AM
Mission DAC5 (DAC7 chipset) ash_dac Digital Source 7 24th September 2009 01:03 PM
Gran Tenor juliovideo Tubes / Valves 14 16th July 2009 09:19 PM
so who owns a dac5 or m8 phono amp builder jb Tubes / Valves 0 21st July 2005 08:47 PM
Dac5 Norbert Digital Source 2 9th June 2003 09:26 AM
