Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
WEILIANG DAC5 - WM8741 & Tenor TE7022
Old 22nd August 2013, 06:31 PM   #301
phase is online now phase  United States
Kent, I have been trying a different biasing setup for the opa627, and it sounds great. The board came with too low of a resistor on the I/V opamps, had distortion. I replaced it with a 2.3K, and it now has less congested bass, better mids.
I am still waiting for my LME49720HA to come, will try that in the output as you have done.
How is your setup working?
Old 22nd August 2013, 07:07 PM   #302
Dr_EM is offline Dr_EM  United Kingdom
Dr_EM's Avatar
Originally Posted by Buccaneer View Post
I too want to use the minishow0328 TE7022 USB module / board as a standalone USB to S/PDIF interface dev board.
minishow0328 has generally been helpful but hasn't been able to help with my problem - then again the guy's a vendor selling with small margins, there is no reason he should help with such unintended use of the board.
Dr.M, did you have any luck?
Mine is connected, I'm powering by supplying +8V DC to pin 4 (Pins 5&6 are ground; the USB interface goes to pins 1,2,3).
The PC recognises a USB connection but says it is faulty and seems not to have loaded the driver, which is installed on the PC. I'm wondering if this is due to absent signals that would normally come from the DAC mobo?
Only just noticed this, sounds like you got the pin-out for the board as I did and have it linked up just the same. Unfortunately the problem you report is exactly what I found, it would just never pick up the device over USB. I didn't have limitless time since it was for a University project so I resorted to using a somewhat more expensive CM6631 based USB-I2S PCB, which does work beautifully.
I really couldn't fathom what it was preventing the Tenor board communicating over USB and tried connecting wires directly in case breadboard capacitance was an issue but to no avail. All the voltages on board were fine, including the 1.8V the Tenor IC regulates itself. There's no extra input to this board that could make it behave differently as far as I could see. If you ever do get it working I'd be keen to hear, it's potentially a high value respectable quality interface.
Old 27th August 2013, 03:53 PM   #303
newondiy is offline newondiy
Default DAC 7 Ver 1.1 high sample rate issue
Hi Weiliang,
Recently I bought a DAC 7 ver1.1 and I paired it with hiface 2 (24/192 Async USB to S/PIF). There were some clicking sound while play audio file with sample rate higher than 96khz. I also tried to turn all the switches to ON and play 24/192 source only and I heared no sound at all, but no problem with CD quality.
I had tested the hiface 2 at the repair center with their 24/192 DAC, it seems to work fine.
Is the DAC broken ? Can you please help ?
Thanks,
Alan
Old 8th September 2013, 06:36 PM   #304
triode_al is offline triode_al  Netherlands
triode_al's Avatar
TE7022L pinouts and basic data are linked from manufacturer's website here:
TE7022L - GFEC
Since my last post by co-incidence within 5 minutes I got another email from minishow0328 [that's an eBay handle by the way and I can vouch he is a very good eBayer with good English].. I now have schematics for the USB interface daughter card. Won't post them here as they are someone else's work -but I think it's fair use to give the CONA pinouts for the daughter board:
_Pin________Funct___
01 USB Vbus
02 USB DM
03 USB DP
04 D8V (8V dc in from DAC)
05 GND
06 GND
07 LRCK2
08 DATA2
09 BCK2
10 SCK2
I assume pins 7 through 10 are the I/\2S interface to the DAC.
The TE7022L SPDIF pins do not go anywhere on this little board except of course for the pads on the IC outline, but it should be possible to connect to them with a couple of bits of kynar wire. So far I haven't done anything about that as getting the USB endpoints established first seems the logical way to proceed.
If anyone else here has tried this, I'd love to know how you got on...
What is the function of the pin 04 (8V in from the DAC), does it set anything?
In other posts with pin information the pin 4 is not connected.
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
Old 11th September 2013, 02:01 PM   #305
kentxon is offline kentxon  Hong Kong
i did replaced more components , sound was getting better and better ,until.....
unfortantely, while i tried replaced the wm8741 AVDD regulator(LT1083-T) with a fixed 1083 5v output, i've blow something again, 2 of the pins grew red hot(analogue output) and the unit was dead, AGAIN. so desperate...
i did order a 8740 for trail and error, but it didnt get a coax lock signal, find very struggle to fix it.
brought the es9018 kit from weilang, sound was so good.
May you share which resistor replaced with a 2.3k?
Old 14th September 2013, 05:23 PM   #306
Kent, very sorry to hear about your 8741 troubles, I hope you can get it back again soon.
I have removed the biasing resistors for my opa627, and replaced them with 2.2K resistors directly on the opa627 pins of each op amp. The sound is great now, way better then before, might try 2K resistors, but I like it now.
Next are mundorf AG in power supply main...
Old 16th September 2013, 08:58 PM   #307
RajkoM is offline RajkoM  Bosnia and Herzegovina
RajkoM's Avatar
Default Back to DAC5
Back to the post No. 111
Finally had time to do a little work on my DAC5. Courtesy of Mr Weiliang I got a scheme, and immediately saw that WM8741 analog PSU is possible to significantly improve. Original PSU is simplest possible - LM317 with two resistors and two capacitors, nothing less nothing more.
For simplicity I chose to make a PSU with LM7808 and cascading cap. multiplier on output. Everything is located on a small PCB 2x2 cm and were used on both sides of the PCB.
Final capacitor is my favorite capacitor for audio - Styrene. Placed close to the DAC chip.
Their efforts paid off. I recommend to all owners of this DAC that changes the analog PSU for WM8741.
Best diying
Old 17th September 2013, 07:51 AM   #308
triode_al's Avatar
Best diying
Do you set the output to 5 volts?
Is that also on the Vb pin of the connector (pin 1)?
Old 17th September 2013, 08:28 AM   #309
RajkoM's Avatar
Yes, Vout is 5V. Set this voltage with 5K trimpot.
"Conector pin 1"..... You mean pin1 on 7808 or what?
Old 18th September 2013, 01:58 PM   #310
RajkoM's Avatar
Two days of listening is enough for capacitors to "settled down".
I controlled output voltage of my new regulator. Dropped to 4.88 V on DMM. I set it to 5V and closed the box.
Really step up in sound quality.
WEILIANG DAC5 - WM8741 & Tenor TE7022Hide this!Advertise here!
Info on Tenor TE7022? chaparK Digital Source 23 1st January 2016 01:46 AM
Mission DAC5 (DAC7 chipset) ash_dac Digital Source 7 24th September 2009 01:03 PM
Gran Tenor juliovideo Tubes / Valves 14 16th July 2009 09:19 PM
so who owns a dac5 or m8 phono amp builder jb Tubes / Valves 0 21st July 2005 08:47 PM
Dac5 Norbert Digital Source 2 9th June 2003 09:26 AM
