WEILIANG DAC5 - WM8741 & Tenor TE7022 - Page 21 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd February 2013, 05:00 PM   #201
Dr_EM is offline Dr_EM  United Kingdom
Dr_EM's Avatar
Does anyone have the pin-out and/or schematic for the TE7022 plug-in module? I'm intending to use it to add USB connectivity to my University project which currently has just S/PDIF.
I know the Tenor TE7022 IC includes an S/PDIF output but don't know if it comes out onto one of the pins on the module header? Also I will need to know what power supply requirements it has.
It should still be far easier to implement than the bare TE7022 IC which would need a PCB layout and difficult soldering (the rest of the project is on prototyping boards).
Any insight much appreciated!
Old 23rd February 2013, 07:25 PM   #202
iSP is offline iSP
Hi
I just assembled a kit with a friend of mine who is used to soldering PCBs (I'm not).
We used some different caps in the power-supply and changed the SMD resistors to two normal ones (we lost a resistor during unpacking...), of course these resistors are not shortcutting anything.
When powering the board, the LEDs at the powersupply part of the board and the one near the crystal (the power indicator) light up just fine. But.... the board generates a medium pitched (at about 200Hz I guess) tone. When powering off the board, it generates a way higher frequency spike for about half a second.
Our setup:
- 2x 9V amplimo transformer
- 2x 15V amplimo transformer, in serial mode, so -15, 0 +15.
Also this sound is also being produced while having the opamps unplugged. The other channel seems to be silent (which is fine), although we haven't tested it with real input yet since I don't feel comfortable having a malfunctioning (oscillating) PCB running....
How can we debug this?
Old 24th February 2013, 07:24 AM   #203
Default opa627
Hi
I have the dac7. I have used opa275, lme49720ha, opa727, ad825. All dual versions (like it should). I have not try the opa627. But of these opamps the ad825 surpasses them by numbers!
Equipment: DK Signature, Denon mod + dac7, Nirvana sx, Master Contempory C speakers.
batalok
Old 27th February 2013, 01:39 PM   #204
Opa627 arrived. Nothing exciting. Maybe i got a fake. Oh well..
Old 27th February 2013, 10:02 PM   #205
Dr_EM's Avatar
Tenor module ordered, hoping I can figure out the header by tracing the PCB back and looking at the, admittedly basic, TE7022 datasheet if nothing else!
Old 28th February 2013, 03:49 AM   #206
Originally Posted by linuxworks View Post
yes, they set the dac hardware filter flags, relating to samplerate range.
2 since one is for each dac chip.
there should have been more switches. anti-clip, for one. pin26 is left floating or grounded and I prefer to have the 2db anti-clip feature on, so that means lifting or never soldering down pin26 of the 8741 chip.
what is anti-clip feature of the 8741 means? (sorry I asked, I am not into electronics)
Recently, I fixed up the DAC7 (by Weiliang), hooked it up to my CD player via Optical. It works fine, but sometimes there is an annoying sharp "crackling" sound (lasted 1 sec the most) whenever I skipped tracks during CD playback.
Could this anit-clipping feature help to solve this?
Phil.
Old 28th February 2013, 04:09 AM   #207
linuxworks's Avatar
sounds like the cd player is not muting between tracks.
anti-clip won't help with that.
dacs can also detect various spdif conditions and mute themselves. some do it better than others.
My Photostream:http://www.flickr.com/photos/linux-works/
Old 28th February 2013, 04:35 AM   #208
If that is not the cure...Oh no...!!
Old 28th February 2013, 04:30 PM   #209
I did more test run and found that the crackling noise does not happens all the time, there is a mute feature at pin 25 on the WM8741 perhaps I can think of something for that.
Old 2nd March 2013, 09:17 AM   #210
gugi100 is offline gugi100  Netherlands
I am about to solder the WM8741. I am a bit confused about this item. The datasheet states for pin 26:
De-emphasis Control
0 = normal operation
1 = de-emphasis applied
Z = anti-clipping digital filter mode
Now if i leave pin 26 simply unconnected goes it into Z mode? Or do I need to connect pin 26 with pin 21 Zflag zero flag output?
link datasheet wm8741
Gr GJ
Info on Tenor TE7022? chaparK Digital Source 23 1st January 2016 01:46 AM
Mission DAC5 (DAC7 chipset) ash_dac Digital Source 7 24th September 2009 01:03 PM
Gran Tenor juliovideo Tubes / Valves 14 16th July 2009 09:19 PM
so who owns a dac5 or m8 phono amp builder jb Tubes / Valves 0 21st July 2005 08:47 PM
Dac5 Norbert Digital Source 2 9th June 2003 09:26 AM
Copyright 1999-2017 diyAudio
