WEILIANG DAC5 - WM8741 & Tenor TE7022 - Page 20 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd January 2013, 05:14 PM   #191
i got my DAC7 with CM6631 chip, but i found the below problems:
1.) i cannot play 176k file via USB, does CM6631 support 176k rate??
2.) when playing 192k file, the sound got noise (glitches sound)
anyone know how ot solve this problem?
P.S. my source is Linux MPD server ALSA output...
Old 22nd January 2013, 06:51 PM   #192
gugi100 is offline gugi100  Netherlands
Originally Posted by vinodt1347 View Post
I have just checked out the DAC7. It sounds quite good though I have concerns about the power supply design as there is a lot of heat being generated.
Hi vinodt1347,
I am starting the build of the dac 7. I have a some questions.
Which parts of the powersupply get very hot. Is it the analogue shunt supply or the digital supply or the analogue wm 8741 supply? What tansformer values do you use?
thanks Gr GJ
Old 22nd January 2013, 07:33 PM   #193
Its the 4 larger heatsinks on the board, near the capacitors. I guess these are the analogue shunt supplies. I used the 15-0-15 and 2 x 9V transformer rated at 30W. As I said here, I have also tried the AK4396 DAC which is about 1/2 the cost and I did not see a big difference.
Old 22nd January 2013, 07:40 PM   #194
Hi, I just stuck a slightly larger heatsink onto the heatsinks that were radiating the most heat. Its much better now.
Old 23rd January 2013, 12:38 AM   #195
Thank you Vinodt1347,
Good to know it are the analogue shunt larger heatsinks. I have also have bigger heatsinks laying around :-)
Gr GJ
Old 23rd January 2013, 10:37 AM   #196
Has anybody ordered OPA627s from the same vendors? Those OPAs are abnormaly chip and must be not original. What do you think about the quality?
Old 23rd January 2013, 07:17 PM   #197
merlin2069er's Avatar
Send a message via MSN to merlin2069er
I've got one of these TE7022 24Bit 96Khz usb to is2 (or spif) units but doesn't seem to like Windows 8.
Anyone know where to get a driver for it (for windows 8)?
Old 7th February 2013, 03:00 PM   #198
kentxon is offline kentxon  Hong Kong
I had the Dac5 Kit (v1.7)
I seems get a signal locked from s/pdif (the middle LED light up), however, i didn't get any sound from the RCA out, measure with digital meter, i get a 2.2 dc output from left channel.
does that mean i had done something wrong with it?
thanks for your help.
Old 13th February 2013, 01:58 PM   #199
Hello,
I'm planning to buy a DAC7 but I'm not sure about the op-amps. I read that changing the opamp will cause a great sound improvement, but what about the quality of the OPA627 from "minishow0328"? Here in Germany I would pay over 20$ for one OPA627...
Anyone who ordered them and tested?
Would be very grateful when someone could give me a hint
Greetings,
Kai
Old 23rd February 2013, 09:09 AM   #200
Originally Posted by WaterCooled View Post
Hello,
Greetings,
Kai
ordered a pair of used opa627 waiting....for the postman..
Info on Tenor TE7022? chaparK Digital Source 23 1st January 2016 01:46 AM
Mission DAC5 (DAC7 chipset) ash_dac Digital Source 7 24th September 2009 01:03 PM
Gran Tenor juliovideo Tubes / Valves 14 16th July 2009 09:19 PM
so who owns a dac5 or m8 phono amp builder jb Tubes / Valves 0 21st July 2005 08:47 PM
Dac5 Norbert Digital Source 2 9th June 2003 09:26 AM
Copyright 1999-2017 diyAudio
