WEILIANG DAC5 - WM8741 & Tenor TE7022 - Page 14 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th October 2012, 02:47 PM   #131
Hi to all,
My first post btw, I bought V1.9 DAC and would like to add volume control.
Can it be done with just adding the resistors at the output (like serial plus shunt)? Why is the buffer needed and can we live without it? I plan to go directly to the power amp with 1V sensitivity, I measured the dac output and it's above 2V for 0db source.
Old 11th October 2012, 07:07 AM   #132
Weiliang,
I just ordered a DAC7. Do you have a schematic I could have? Also, I couldn't find a description for the dip switches or the switch on the back.
Thanks.
Old 13th October 2012, 02:43 PM   #133
Originally Posted by atharva View Post
Hello Weiliang,
I have purchased the V1.9 Dac 5 as well. Can you email me the schematic?
rwankar@gmail.com
- Ravi
Hello, sent it to your email already!
Old 13th October 2012, 02:45 PM   #134
Originally Posted by batalok View Post
Dear Weiliang
I forget, my email is k dot tan at tiscali dot nl.
batalok
Hello, sent it to you already
Old 13th October 2012, 02:46 PM   #135
Originally Posted by maynard999 View Post
Weiliang,
Thanks.
Hi, pm me please, tks
Old 13th October 2012, 04:12 PM   #136
Hi, weiliang!
I've just built DAC5 V1.9, but there's no sound at all...
The LED's light up, USB connection works... but silence.
Could you please provide the schematics and some suggestions how to investigate the trouble?
Thanks!
Old 15th October 2012, 09:46 PM   #137
Originally Posted by kristijanpop View Post
Hi to all,
Anyone ?
Old 16th October 2012, 02:09 PM   #138
Hello Weiliang,
I have received my DAC 7 v1.1 yesterday. Can you email me the schematic (only for my personal use)?
a.coroama (at) gmail com
Thank You!
Old 22nd October 2012, 11:03 PM   #139
Originally Posted by yvlasenko View Post
Hi, weiliang!
After a while, I've found the problem, it was a weak soldering of D74HC157. After I've re-soldered it, everything's ok
Old 23rd October 2012, 10:10 PM   #140
Hi guys!
I'm looking into building a pre-amp using a Raspberry PI over USB and a toslink/spdif panel. As a DAC the stuff weiliang designs looks very promising.
I've read that the switch toggles between coax and optical but I can't find out how the board switches between USB and spdif input. Is this just a matter of not sending a signal or is there something else involved. And if so, how does the board behave when both channels receive a signal?
Thanks!
Ernst
Info on Tenor TE7022? chaparK Digital Source 23 1st January 2016 02:46 AM
Mission DAC5 (DAC7 chipset) ash_dac Digital Source 7 24th September 2009 02:03 PM
Gran Tenor juliovideo Tubes / Valves 14 16th July 2009 10:19 PM
so who owns a dac5 or m8 phono amp builder jb Tubes / Valves 0 21st July 2005 09:47 PM
Dac5 Norbert Digital Source 2 9th June 2003 10:26 AM
Copyright 1999-2017 diyAudio
