CD player sometimes sounds like "stuck LP" - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 30th April 2012, 04:24 AM   #1
HCB is offline HCB  Australia
Default CD player sometimes sounds like "stuck LP"
I have a Shanling CDP100 which sometimes sounds like a stuck LP, cant think of another way to describe it... It is much more common burned discs, but certainly happens on others. Any ideas as to what might be the cause of such a problem? Thanks
Old 30th April 2012, 12:14 PM   #2
A weak (old) or missaligned (out of focus) laser could do that. E
Old 1st May 2012, 11:52 AM   #3
Thanks. I have tried cleaning the lens, not really any change. As with so many problems, this is intermittent, but quite frequent enough to cause substantial irritation. I dont really want to send the player off for repairs, am happy to try and install a new laser if need be, or else simply sell it on to someone willing to take on the problem. This is not in my comfort zone.
Old 1st May 2012, 02:35 PM   #4
I didn't say it is the laser, just that it could be. Unless it is a very expensive player, the replacement of the laser assembly is not worth it.
There are other mechanisms in a CD player that could cause this problem. See this link: Compact Disc - Wikipedia, the free encyclopedia
Old 1st May 2012, 03:54 PM   #5
poynton is offline poynton  United Kingdom
poynton's Avatar
If it is the version which uses the Philips cdm12.X mechanism, then cleaning off all the old grease on the drive chain and sliders can sometimes help.
Its a known problem!
Do not regrease though.
Andy.
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 1st May 2012, 10:28 PM   #6
Thanks to both of you for your comments. It is a reasonably expensive unit, but is getting on a bit in terms of age, so could be any number of issues. Simple stuff first is good, so I will clean up as suggested, hopefully this will resolve the issue.
Rotel RCD-855 CD Player "ERR" Message dtm1962 Digital Source 21 16th July 2016 02:20 PM
How can I add a "Digital In" to my current cd player ? (Make it work as a DAC ) b_online Digital Source 3 29th October 2014 01:37 AM
"A standard CD player outputs signal at 24V" wwenze Digital Source 16 13th July 2009 04:50 PM
What's the difference between CD Car Headunit and CD Home Player "line output" ? calico88 Solid State 1 1st August 2008 09:54 AM
Overlooked "High End" CD-player ! Cobra2 Digital Source 12 17th January 2004 12:28 AM
Copyright 1999-2017 diyAudio
