| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi all,
I am currently looking to improve the sound quality of my AC Ryan Mini HD II by using an external DAC. Would appreciate anyone who has used media players and noticed improvements after using an external DAC. Can anyone recommend a budget DAC (<$100) that will accept Toslink input and output analogue L+R? Does not need to playback 24bit 192Khz files. My media player outputs LPCM audio. The Fiio DAC has crossed my mind, though I am unsure if it will bring about any improvements. Regards, Dinesh
Sand till the end of time
#2 |
Anything will be better. Those media players are using the DAC integrated in the main cip, that is just sufficient for movies, not for music. Fiio DAC is not that much better.
I would take a peek on eBay for some DAC's that are described on the posts here. Burr Brown/Texas Instruments, Analog Devices, Cirrus Logic, Wolfson Micro... choose your poison
#3 |
Sorry, don't ave a solution for you, but you are addressing something I'm clueless about... What comes out of the optical output of modern equipment.
I have a Mini HD2 also and I have a 1990 JVC amp with build in DAC (AX-Z1010). Can I hook the amp up to the HD2 (optically)? What do I need to change in the settings? Where can I read up on this to understand what will work and what not? (I googled it and asked elsewhere last week about finding some more info on the subject). Last edited by ric-paul; 29th April 2012 at 11:35 PM. |
#4 |
Thanks Sonic, I will look into those DAC's.
@ ric - Does your amp have a digital input like optical(Toslink)/coaxial? Otherwise you can still connect the amp to the AC Ryan via the analogue RCA (L+R) connections. I have found a Yulong DAC, however it will be outside my reach for a long time...
#5 | |
But my problem is that I don't have a clue what comes out of my TV or HD2. Is this 5.1? Will my amp simply not understand this? Or is the stereo somehow embedded within the 5.1 signal and will my amp understand this part of the total signal? I don't even know what questions I should ask, that's how little I know about it
#6 |
The surround via SPDIF (digital) will come only in form of DolbyDigital or DTS - lossy compression was needed because the SPDIF bandwidth doesn't allow more that stereo PCM.
You would need to setup your source to output stereo PCM signal. Not all sources can do that since it would require decoding of DD/DTS signals. Some cheap TV will just pass-trough without decoding. Your HD2 should have the option in menu to down-mix surround to stereo. |
#7 |
I have a Playon!HD 2 that i connect to a Denon DA-500 dac and use the coaxial output of the player, but optical is also possibe.
The players setup menu as an audio section and a spdif submenu that lets you set the output to PCM which works fine for the DA-500. Wouter |
#8 |
I've hooked my AC ryan media player up to a Behringer ultramatch 24/96. Works like a charm. If you play audio files you can select passtrough in the audio setup of the AC ryan. If you select PCM it will resample everything to 48KHz.
Music is art - Audio is psychoacoustics & engineering |
#9 |
Wouter and Mark,
Can you comment on any audible differences you noted with the DACs?
#10 | |
In the audio menu I can select SPDIF and the only options I have are LPCM or passthrough. Wiki says LPCM is roughly the same as PCM so that should work, right? Will try it asap (just hauled the 18kg/40lb sub and same weight amp up two floors...now they have to come down again for testing this |
| External DAC | avidedtr | Digital Line Level | 1 | 15th August 2010 04:06 PM |
| Valab external dac will work with my nos dac? | noyan | Digital Line Level | 2 | 9th May 2010 04:17 PM |
| Designing an External DAC | Chris_F | Digital Line Level | 10 | 27th January 2010 06:49 PM |
| old multıbıt DAC ın new external DAC box | sergiof | Digital Source | 2 | 8th April 2009 10:45 PM |
