How to calculate fs bit clock knowing crystal frequency? - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th April 2012, 05:20 PM   #11
merlin el mago's Avatar
Yes I want to use I2S to connect the TP Teleporter but I know that Buffalo III needs 64fs as bit clock so that's the reason that I want to know how much fs of bit clock have my CEC TL1.
The servo chip is a Yamaha YM7121C, datasheet link: YM7121C datasheet pdf datenblatt - YAMAHA CORPORATION - SIGNAL PROCESSOR AND CONTROLLER (AND RAM ) FOR COMPACT DISC PLAYER (SPC V) ::: ALLDATASHEET :::
Thanks in advance for help
Old 27th April 2012, 09:15 PM   #12
glt is offline glt  United States
Oh sorry,
That was the calculation for the "master clock"
The bit clock is also implementation dependent, and irrelevant of the source clock. Most CD drives will output at 32*fs (16 bit for the left channel and 16 bit for the right channel). Most I2S compatible devices will output 64*fs (32 bit for L and 32 bit for R, padded with zeros if there is no data beyond 16 bit or 24 bit)
Some DACs such as the wm8741 supports both 32*fs and 64*fs. The ESS as you said, only 64*fs
If you look at p11 of the datasheet, the serial output seems either 32*fs or 48*fs, therefore it will not work with the ESS DAC
www.hifiduino.wordpress.com
Old 27th April 2012, 09:46 PM   #13
When you said "not work" do you refer "no sound" or do you refer can sound with dropouts?
Old 28th April 2012, 01:28 AM   #14
I don't know. Try it...
Old 28th April 2012, 09:04 AM   #15
If use S/PDIF I will have the same problem: "not work"?
Old 29th April 2012, 12:13 AM   #16
kevinkr's Avatar
Unlike I2S SPDIF is quite standardized and the ESS dac should work fine with a SPDIF input..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 29th April 2012, 02:09 AM   #17
5th element's Avatar
Typically the data clocked into a device is done at the rate of the bit clock. The LR clock goes high or low to determine whether or not the data passing to the device is for the left or right channel and during that time the data for that channel is clocked into the device using the bit clock and the data stream. Even if the device is expecting a certain number of bits per LR period it will still recognise what data is meant for which channel. The question is whether or not the device will cope with receiving the incorrect number of bits. My guess is that if it works it wont do so gracefully. If the device was capable of filling in the missing bits with zeros then surely it'd be listed as being capable of working with a lower rate bit clock. You could email the people at ESS and ask them.
I thought the ESS chip had an SPDIF receiver built into it? If it does then that will work fine as the receiver will output data that the DAC is capable of working with.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 29th April 2012, 03:03 PM   #18
Thanks for support guys,
@glt I will try
@kevinkr Works with dropouts
@5th element If not work the solution will be to buy a TP Metronome to upsample to 96fs
Old 24th February 2016, 11:12 PM   #19
Salar is offline Salar  Germany
IŽll resurrect this thread:
I have some interesting example of a Sony CDP-103 from 1985 where the bit clock is used to drive the control circuitry/logic.
According to the service manual, pulse width of the bitclock is 240”S, the bitclock is derived from a 8.4672 master clock (which is made from 16.9344 using a divider).
Which frequency has the bitclock ?
To find the trace of the bitclock, look at IC 304 in the middle of the schematics, it buffers the bitclock.
All the best,
Salar
Old 25th February 2016, 02:02 AM   #20
The 240us. period shown on the schematic cannot be an audio bitclock rate because it simply is too low, equaling a frequency of, 1/240us. = 4,166.7kHz. The units of the figure shown in red may be a typographical error, more likely being 240 nanoseconds. This would result in a bitclock frequency of 4.1667MHz, which is very close to being exactly half the 8.4672MHz master clock frequency you cite. Perhaps, that 240us. figure shown in red on the schematic was measured by eye from an o-scope graticule, and not only should be in nanoseconds, but was actually 236.2ns., which would then exactly equal half the master clock frequency.
Ken
16AKSS7ET crystal frequency xplod1236 Parts 1 8th December 2006 04:54 AM
Marantz CD11 crystal frequency ? joeling39 Digital Source 0 6th June 2006 10:42 AM
low ppm crystal clock?m where tone Digital Source 6 27th February 2003 10:23 AM
5.6448mhz clock (crystal) glewis4744 Digital Source 1 16th January 2003 10:18 PM
crystal frequency question pjkunz Digital Source 6 6th December 2001 02:31 PM
Copyright ©1999-2017 diyAudio
