| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
If a moderator would change the topic to "Parallell TDA1541A's/Balanced+parallell TDA1541A's" I would be grateful. I'm no longer trying to piggyback the TDA's but rather trying to design a PCB with either 4xTDA1541A in parallell or in balanced(differntial)/paralllell(2+2).
#12 |
Spent about 2 more hours on this project today(in eagle).
It's comming along, but very slowly. |
#13 |
I've created a number of parts in eagle now, DIR9001, SAA7220 and more to have options.
Once I got the hang of it it's quickly done. |
#14 |
Hi Mayday
I am sure you have seen this, but there is a tremendous body of work on the ecdesigns thread where he explores multiple chips in parallel and then comes back to one with very careful design. Building the ultimate NOS DAC using TDA1541A It is a multi year journey with many of the tda experts weighing in. Long but a great source of research. |
#15 |
Hi
![]() I've started reading that thread, it's a long one. I was thinking maybe a differential design with 2 tda's per channel. Haven't really gotten very far though, this will be a long term project
#16 |
Meanwhile I hope you are still enjoying your 1541a masterpiece. Some of the areas that are worth consideration coverd by ecdesigns include:
DEM reclock is a winner. Of course low noise discrete reg for each power consumer. His bypass cap made of a double sided pcb. (brilliant) I cheated and used a silver mica to bypass Russian MGBO2 POI for coupling cap. Another winner that some claim beat a VCap for pennies. SMT decoupling caps soldered direct to 1541a pins. Awesome. My next thing is to build his double helix resistor for the passive I/V. No end to 1541a fun. |
#17 | |
![]() But I did put alot of thought into that build and used the best parts I could reasonably afford. I do enjoy it, the MayDac(as I call it) will stay for a very long time as my main D/A converter. The project I'm tinkering on now is very long term, it's fun working in eagle and hopefully I'll get a nice design and layout in the end ![]() I think a differential design with two TDA/channel, one for +out and one for -out might be a good way to use multiple TDA's? 1541A's are fun, and it's easy to get bitten by that bug since they are so grateful for mods/upgrades....you hear results when giving them better working conditions. It would be difficult and expensive, but one dream of mine is to use 4 tda's as above and then after I/V connect the differential outputs of each channel to a signaltransformer for single ended outputs. |
#18 |
This may help you
![]() This is my release candidate board - a bit of silcscreen fixes, graphics, GND vias and pads for copper shields attatchment will make it 100%. http://s3t.it/data/uploads/dac_1541_v011.png Historical layouts from recent to where it started: TDA1541A |
#19 |
Thank you
![]() I'll look at the links when I get home, on my cellphone now. |
#20 | |
Will you use a single TDA1541A? Thanks for sharing
| For Sale : dvb-projekt "Reference" TDA1541A DAC PCBs | Thesoundmen | Swap Meet | 1 | 27th July 2011 03:21 AM |
| FS: Analog Metric DAC TDA1541A S1 | Amauta | Swap Meet | 3 | 13th July 2011 04:19 PM |
| FS: NOS TDA1541A S2 "Double Crown" | adhoc | Swap Meet | 14 | 14th March 2009 07:50 PM |
| Randy Slone's "Fig 11.4" (Self's "Blameless"?): PCB layout | tcpip | Solid State | 126 | 15th February 2007 04:50 PM |
| "Total Aural Dissonance" - the proper metric? | jackinnj | Everything Else | 11 | 26th August 2004 12:39 PM |
