Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
question on dac power supply
Old 16th April 2012, 11:12 AM   #1
Professor smith is offline Professor smith  United Kingdom
Banned
Default question on dac power supply
my dac needs 15v 1.7Amp dc. What happens if you supply 15v 1.2Amp instead? will the lower current damage it?
Old 16th April 2012, 12:24 PM   #2
R.I.P.
What will happen depends on the actual current draw of the DAC,
not the specified current rating of the supply, and how the supplies
are current rated in the first place, and how they are protected.
Supplies with overcurrent protection will shut down the output,
other supplies may simply get hotter, generally its hard to say.
FWIW though I'd expect the actual current draw of the DAC
to be far less than 1.7A and the 1.2A supply to work fine.
There is no reason the lower rating would damage the DAC.
rgds, sreten.
Old 16th April 2012, 01:38 PM   #3
Banned
hi,
well i am changing the supply from a switch mode to a linear regulated one. Should this yield an improvement? I just got hold of a cheap linear one just to see if there is a difference. If so I would consider getting an even better linear supply.
Old 16th April 2012, 02:19 PM   #4
Banned
i tried it and i got some low level buzzing and noise coming from the speaker. Why is that? a poor quality power supply?
Old 17th April 2012, 01:33 PM   #5
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
Originally Posted by Professor smith View Post
hi,
Unfortunately, the words, hifi - power supply - cheap, usually don't mix well. First, I would place a D.C. voltemeter on that new 15V supply while it is powering your DAC to verify that it does indeed supply at least 15V under that condition. Even so, you may be better off with the original switching supply unless you are willing to invest some serious effort or money on a top quality linear supply.
BTW, switching regulators are not necessarily contrary to good hifi. Linn has used them for many years now. It depends on how well filtered the output of that supply is across a very broad band of frequencies, which extend in to the RF region.
Old 17th April 2012, 09:43 PM   #6
DF96 is offline DF96  England
Grounding may be an issue to investigate.
question on dac power supplyHide this!Advertise here!
Question on DAC power supply (general) & interconnection to source coolnose Digital Source 0 9th October 2010 04:33 PM
Dac Power Supply kkchunghk Power Supplies 3 13th September 2008 03:19 PM
DAC Power supply elec-tron2 Digital Source 1 7th April 2007 11:57 PM
non-os DAC power supply.. reMC Power Supplies 1 11th June 2005 12:54 PM
DAC power supply Qs tiroth Digital Source 2 3rd May 2002 03:59 PM
