MayDus, PCM2706/CS4398 USB DAC w Transformer output. - Page 8 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th July 2012, 12:22 AM   #71
freddi is offline freddi  United States
freddi's Avatar
I'll eventually pick up the 2.5W units but will have to find someone else to do the work as can't see very well plus only slung solder in tube stuff.
there may be some flavors to different iron. I've hooked up a $10 (at the time) Belkin in-wall transformer to regular CD player as volume control - for frequency response, it measured very well even down to its maximum attenuation but its contribution (very pleasant - not sure how hard on opamp) could be heard on a little Karlson which was loaded with Beta 8cx and APT50 on a tenor with guitar CD. Likewise, a Promitheus TVC's harmonics can be heard in A-B comparison on a horn system - oddly that seemed to make the 3 drivers and funky Klipschorn style crossover blend more cohesively.
Old 20th July 2012, 11:04 PM   #72
Hi Ryssen, Did some experiments with my CS4398, LL1690 dac. I found some improvement by going to shorter length cables with lower capacitance. The "details" are better. I think it is worth trying several different cable. It seems you can "tune" the dac somewhat. My best results was with a homemade cable made from a double run of RG179U (If memory serves). That has Teflon insulation Silver wires and a FEP jacket.
Old 20th July 2012, 11:14 PM   #73
Hi freddi, I use one of those flourescent lighted work lamps with a magnifying glass in the center. Makes working on things much easier. I am very far sighted now that I hit 50. Can see street signs and read them from great distance, just don't see well up close. I will be putting my Edcor 2.5 watt transformers into a bud box with a shield between them. Trying to protect from ac line noise etcetera. Stray magnetic fields. The Edcors don't have the MU metal that Lundahls have. I do prefer transformers over opamps or capacitors in dac's.
Old 21st July 2012, 12:12 AM   #74
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
When the hollidays is over in about a week I can order mine LL1690 from Lundahl and start listening.
Regards Åke
Old 21st July 2012, 02:46 AM   #75
Hi Ryssen, Let me know how it sounds to you. I'm interested in your opinion. Regards, Dave
Old 21st July 2012, 09:59 AM   #76
Ryssen's Avatar
I will.
Regards Åke
Old 4th August 2012, 08:24 PM   #77
Hi Ryssen, Did you try the LL1690? I have made a few experiments. Made a few changes to my home built preamp. I replaced the wires to my 50K 23 step Chinese attenuator. Also tried an Alps blue conductive plastic potentiometer. Big difference in sound quality. Still prefer the attenuator. The heavier wire helped bass response. I will be giving the CS4398 and LL1690 another listen this week. Dave
Old 4th August 2012, 08:33 PM   #78
Ryssen's Avatar
I ordered in the beginning of this week,hopefully I´ll get in on monday.
Regards Åke
Old 8th August 2012, 03:18 PM   #79
Ryssen's Avatar
I got the trafos today will install them this evening.
Regards Åke
Old 8th August 2012, 08:31 PM   #80
Ryssen's Avatar
Been listening for about an hour now and the first difference from LL1540 is that it sounds harder maybee more dynamic.
Dave do you use a resistor between the DAC chip and LL1690?
Regards Åke
CS8416+CS4398 DAC Kit Support USB + coaxial DAC Board bleachershane Digital Line Level 4 2nd February 2015 10:45 PM
PCM2706 USB DAC - Interference/Temperamental Connection browner Digital Source 36 11th May 2008 06:06 PM
How to do Self-power for USB dac pcm2706? ChuckT Digital Source 15 20th March 2006 01:53 PM
3.3V PSU to drive PCM2706 USB DAC Nordic Digital Source 21 11th February 2006 04:09 PM
Advice on part selection on USB PCM2706 TDA1543 DAC swak Digital Source 0 1st November 2005 12:04 AM
Copyright ©1999-2017 diyAudio
