Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Is There a "Standard" for CD Antialias Filtering?
Old 6th April 2012, 05:01 PM   #21
SoNic_real_one is offline SoNic_real_one  United States
First digital recodings where done in 70's by PCM modulation and recorded on video magnetic gear (U-Matic). Since the machines where NTSC standard, audio datarate needed to comply with that and resulted number was 48kHz.
Alesis made in 1991 the first multitrack recorder, the 8-track ADAT on a S-VHS tape. Original was 16 bit (upgraded to 20 bit latter) and 48kHz resulted from NTSC framerate - dual speed added later for 44.1kHz.
Is There a "Standard" for CD Antialias Filtering?Hide this!Advertise here!
What's current "best" opamp for active filtering? sdad Parts 10 26th March 2013 02:32 AM
Using a standard pentode-tetrode as output "space-charge tube" any ideas-experiences? bembel Tubes / Valves 12 11th March 2010 05:56 AM
"A standard CD player outputs signal at 24V" wwenze Digital Source 16 13th July 2009 04:50 PM
cheap 6" or 8" woofer to make great bass for a standard cab pick up zuki Subwoofers 12 15th February 2005 07:54 AM
A "Standard Noise Source" for SPL meters. Jonathan Bright Everything Else 6 13th July 2004 10:19 PM
Copyright ©1999-2017 diyAudio
