KSS-210A optical pick-up doesn't stop at initial position - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th March 2012, 07:49 PM   #1
fonon is offline fonon  Poland
Default KSS-210A optical pick-up doesn't stop at initial position
I have NAD 512 with KSS-210A optical pick-up. After power on the the motor try to move optical pick-up in the direction of disc center. The motor doesn't stop at initial position. The optical pick-up presses the sensor.
What to do?
f.
Old 26th March 2012, 05:41 PM   #2
ide2003 is offline ide2003  Indonesia
hi, I'm confused here with your 'initial' position. Did the optic move to the disc center after power up?
if yes, does the lens moving up and down at that center position?
Old 26th March 2012, 06:43 PM   #3
Thank You for answer.
Normally, when the disc is not played, the pick-up remains near to the center of disc. The pick-up is in the same position when the disc is not loaded. I named it 'initial' position.
I can move the pick-up manually. After power up the pick-up moves to the disc center, but the motor doesn't stop.
I must to power off the player immediately in order to protect the motor and gears.
f.
Old 27th March 2012, 12:44 AM   #4
I see, thanks for explanation,
It can be the leaf switch somewhere below the spindle has given up, you can try the following :
just sand lightly in the contact point, test them for connectivity
check solder joints, all wire connectors from transport to mainboard
to test, power off the player, move the optic out of center manually, turn on the player
optic will move to center, and it will hit the switch, see if lens moving up and down,
hope this helps
Databook about SONY's KSS optical pick up series tiefbassuebertr Digital Source 11 14th March 2017 07:58 AM
Sony optical pick-up KSS 273 A cdun Digital Source 11 1st December 2014 03:46 PM
KSS-210A (= KSS-150A Successor) and KSS-212A - what is the main difference? tiefbassuebertr Digital Source 5 7th June 2013 09:00 PM
Problem with repalcement of KSS-212 optical pick-up fonon Digital Source 4 20th March 2012 12:43 PM
Copyright 1999-2017 diyAudio
