Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Better analog or digital audio?
Old 23rd March 2012, 12:01 PM   #1
haik is offline haik
Default Better analog or digital audio?
hello all,
I have the possibility to connect the following:
Amplifier: Yamaha DSP-A1 which uses AK4324 for DAC and UPC4570G2 as an OP-AMP
CD1: Marantz CD67SE using SM5872 as a DAC and NJM2114 as OP-AMP
CD2: Marantz CD4000 using TDA1545 as a DAC and NJM 4560D as an OpAmp.
CD3: Philips CD692 using a SAA7341 as a DAC and LM388 as a final amp.
I can connect both analog or digital (SP/DIF).
Which CD is better and what way is it better to connect (analog or digital)?
If I connect digital then the DAC of the Yamaha is used (AK4324). If I connect analog, then the DAC of the CD player is leading.
Haik
Last edited by haik; 23rd March 2012 at 12:53 PM. Reason: corrected CD2 DAC and Op-Amp. Added CD3
Old 23rd March 2012, 12:26 PM   #2
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
CD2 by all means. Any designer who manages to use a TDA1545 as an opamp is a borderline genius
But more seriously, chip sets are only partly responsible for sound quality. Would be nice if it were that simple but it ain't.
Old 23rd March 2012, 09:00 PM   #3
SoNic_real_one is offline SoNic_real_one  United States
The issue is that the part is like 90%... So it matters a lot.
Unfortunatelly they are all losy DAC's and OpAmps. Slightly better is the AK4324...
Old 6th April 2012, 11:39 AM   #4
OK, I repaired the CD4000 (used an old laser from a Philips which was found at the local garbage dump).
I ordered through e-bay the DAC kit.
http://www.diyaudio.com/forums/digit...93-5532-a.html
I will install it in the CD4000 (lot's of room to spare), and compare the difference with original DAC and the new one, and also the DAC used in my Yamaha DSP-A1 (AK4324).
I will post the results.
Haik
Better analog or digital audio?Hide this!Advertise here!
DIY Analog-to-Digital Converter project.Audio measurements tool Frex Equipment & Tools 288 28th October 2016 04:48 AM
Coaxial Digital Audio to 5.1 analog outputs? pekinin Digital Line Level 2 2nd April 2009 02:21 PM
Using 75-ohm digital coax cable for regular 2-ch analog audio? Glowbug Digital Source 7 12th May 2008 06:27 AM
Differences between Digital and Analog Audio oscarcasalini Digital Source 1 7th January 2004 11:32 PM
Analog to Digital? Ioannis Digital Source 5 11th December 2001 06:52 PM
Copyright ©1999-2017 diyAudio
