| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#21 | ||
So for any disc to spin up and play means that initial focus has been found. The player will have a FOK (focus OK) signal proably marked on the system control/servo IC/s.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#22 | |
CD cannot work without a focus. It will "start" in a certain position, at a certain speed, where it "knows" what RPM is expected to be (beginning of the disc, inner part), but further than that, the loop it really needs the feedback signal from the laser to extract the Linear Speed information. |
#23 |
Hi, just to share some encounters on my CD6000ose KI. Few weeks ago i done some cap replacing but had reversed the polarity of one of the cap that link to a 7918 regulator. When it power up it able to detect the cd and play along. But around mid track the cap burst. I try my luck by replacing just the cap with correct polarity inserted. The cd able to load into but does not spin. So replace the voltage regulator solve the spinning issue.
My cdp had been having cd reading issues for quite sometime and strange enough i did not notice the sound had became very dull and lack of details till i connect to my Audioengine A5+ for a listen. So yesterday i bought a new lens and replace it. Wow, the details and musicality had come back. Today i had let it run-in couple of albums, the sound start to smoothen out cos' initial play sounds harsh and bright. ps My cdp had been chuck one side for almost 3 yrs till i bring it out for improvement project. Thanks for reading.
#24 |
OK guys, it has been fixed.
I took out the laser unit from an old Philips CD692 which by chance had the same VAM1201 unit. Since that was a Cd player which I found at the local garbage dump (and in still working condition!), I cannibalized it for the laser unit. The Marantz recognizes now everything. CD-A and CD-R. Now I need to wait when my DAC kit arrives from China, and make a very nice CD player. Thanks for all the help guiding me into the correct way. Haik |
#25 |
Pleased to hear you have fixed it.
#26 | ||||
I think you're right. I replaced it with the Kenwood but neither shame nor jealousy has made any difference. Actually the problem's become permanent, which I'm a bit happier about. I've determined that the motor control signal from the decoder chip is set at full duty cycle, which is where it goes normally when accelerating from stationary, i.e maximum "too slow" error.Quote:
![]() Quote:
But that chip gets signals concerning the motor from sources other than the laser circuit, and I guess they depend in part on the front panel processor. Specifically, there should be a not(motor stop) signal (dead man's handle). At least there is on the CDM2 machines I worked on before I settled on the CD50. Quote:
cheers, Ian |
#27 |
A good procedure is to pull the data sheets for all the IC's and to work around each pin in turn checking that every pin has the expected voltages/signals/clock etc.I always used a scope for that, even for DC voltages. You check everything... even ground pins. Do the same for ribbon connectors checking their source and destinations with a scope.
Good luck with it when you get around to working on it.
#28 |
Thanks for your help, Mooly.
Ian |
#29 |
Marantz CD4000 is a good cdp.
I would say CAS is the trend. A good DAC (esp. DIY KIT ) may not cost so much more than the laser or lens assembly Last edited by T Leung; 7th January 2013 at 08:45 AM. |
| Selling: Marantz 510m (Broken) | sound_prodigy | Swap Meet | 9 | 9th December 2006 02:05 AM |
| Marantz CD4000....broken. | Lyra | Digital Source | 6 | 19th March 2006 08:30 PM |
| Marantz CD-72 tray gear broken, HeLp! | AlfaRomeo6C | Digital Source | 11 | 13th May 2005 06:39 AM |
| Marantz cd 4000 service manual | Kovax | Digital Source | 2 | 31st August 2002 09:05 PM |
| Marantz Cd-4000 / Philips Cd-723 (tda1545) | maartentje | Digital Line Level | 1 | 10th June 2002 05:28 PM |
