Go Back   Home > Forums > Source & Line > Digital Source
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 29th September 2003, 03:58 PM   #1
liz is offline liz
Question PCM to DSD conversion
Hi everyone
I need a means of converting a standard SPDIF output from PCM (probably just 24bit I2S to start with) into left and right DSD data streams with the appropriate clocks.
I've tried using a signal converter from dCS but this proved unsuitable for the application so I'm thinking of developing an FPGA-based solution.
Just wondering if anyone has developed or even just used a PCM to DSD converter? Any recommendations?
Liz
Old 30th September 2003, 06:12 PM   #2
Default Re: PCM to DSD conversion
I have used the dCS972 and the 3 wire sdif2 interface works well. Can you convert this into what you want; there is adequte info on sdif2.
Old 1st October 2003, 10:13 AM   #3
liz is offline liz
Thanks for the reply fmac.
I'm trying to ***** the performance of a DSD device using a signal source that originates as PCM data, so the conversion process needs to produce a very stable output and so far I've found the dCS972 SDIF2 IF to be too jittery for this application.
Old 1st October 2003, 03:29 PM   #4
I'm trying to ***** the performance of a DSD device using a signal source that originates as PCM data, so the conversion process needs to produce a very stable output and so far I've found the dCS972 SDIF2 IF to be too jittery for this application. [/B][/QUOTE]
Can you not relock? I'd like to know what level of jitter you have found as I don't particularly like the sound of upsampled DSD on the 972/954. However, the 954 is supposed to have dual pll and you may be able to get the recovered data streams from there. I have found the cable connections to be very important.
Is the new firewire type interface any better?
Old 1st October 2003, 03:46 PM   #5
Since DSD is basically a SD-signal at 2.8.... Ms/s some 64x oversampling DA converter might probably be "misused" for this purpose.
Charles
Old 1st October 2003, 06:12 PM   #6
[QUOTE]Originally posted by phase_accurate
[B]Since DSD is basically a SD-signal at 2.8.... Ms/s some 64x oversampling DA converter might probably be "misused" for this purpose.
Can you plrease explain how this relates to Liz@s and my posts?
Thanks.
Old 2nd October 2003, 09:53 AM   #7
I looked up the 972 manual and the DSD data stream looks good. I have also examined the clock out on a scope and it seems to be one of the best I have seen; very square, well damped and no broadening.
One aspect about the dCs connection I have doubt about is the twisted pair connections inside the unit which is far from tidy. May be worth running true 75R outputs from, the pcbs.
Thread Tools
SVC to DVC conversion madstamm Subwoofers 8 13th January 2008 05:45 PM
dB/W/M conversion - M vs 0.5 M ?? MadMutt Multi-Way 3 26th December 2007 01:51 PM
24 to 18 bit conversion ??? Lyra Digital Source 13 9th March 2006 03:03 PM
9v to 12v conversion purprobe Parts 2 17th September 2005 10:37 PM
rca conversion oogared Tubes / Valves 3 3rd September 2005 06:48 PM
Page generated in 0.17968011 seconds (84.52% PHP - 15.48% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
