| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Dear
My CD has two outputs fixed and variable. I want to do wiring mods in such a way as to be able to use the direct output without muting transistors and still use the variable output with muting. As i do not have the CDP service manual or schematics, I would be grateful if anyone could help me to work this out based only on the CDP photos I attach herein Thanks in advance ![]() ![]() ![]() ![]() |
#2 |
Anyone can help?
#3 |
See which pair of transistors are related to the fixed output and just remove them.
The ones at the right hand side in the top pictue look like the level translation and logic drive so it is NOT that pair.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#4 |
I see two pairs, one next to the cable and the other on the left (top picture), but each pair seem to be related to each channel of the fixed output.
#5 |
If each pair seems to be related to just one channel (L or R) then that means the two transistors are used to get a "better" depth of mute. If so then maybe the variable output isn't muted at all.
Your pictures aren't quite clear enough to tell how it all connects without spending a great deal of time tracing it out and flipping between pictures. Just experiment, you won't harm anything by pulling the transistors out. Just make sure you know which type goes where. What is the make and model ? Can we not come up with a circuit.
#6 |
It's Kenwood dp-7050. Unfortunately, i have been unable to find its service manual or schematics on the net.
#7 |
This is slightly different but you can see the general idea. Just trace the circuit out and remove the appropriate transistors. This shows how two pairs of transistors are used to obtain a "deeper" level of muting.
| CD Player with variable outputs | salesmonster | Digital Source | 6 | 31st July 2008 05:05 PM |
| Generic snubber values: fixed-/variable-voltage regs | hollowman | Power Supplies | 44 | 28th April 2008 10:09 PM |
| Double variable outputs for BOSOZ | gchrist | Pass Labs | 10 | 20th January 2008 03:38 PM |
| Schematics for a fixed attenuator on DCX outputs | akunec | Digital Line Level | 5 | 16th January 2006 07:17 PM |
| Can a fixed and variable LPF be used at the same time? | GuyPanico | Subwoofers | 2 | 8th April 2005 05:53 AM |
