Is AD829 and AD811 electrically compatible with NE5534? - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th March 2012, 04:17 AM   #1
Default Is AD829 and AD811 electrically compatible with NE5534?
Can I swap the a NE5534 by AD811 or AD829?
AD811 is a current feedback op-amp, so I reckon it's not compatible with NE5534, ist that right?
Are the above mentioned op-amps good for DAC output?
Old 16th March 2012, 05:18 AM   #2
See my blog http://my.opera.com/opamp particularly for detail of op amp power supplies.
AD811 data sheet states:The AD811 is a wideband current-feedback operational amplifier, optimized for broadcast quality video systems. The -3 dB bandwidth of 120 MHz at a gain of +2 and differential gain and phase of 0.01% and 0.01 (RL = 150 W) make the AD811 an excellent choice for all video systems.
although its pin out is standard single op amp, it does have application as a dac buffer see:
AD811 | High Performance Video Op Amp | Operational Amplifiers (Op Amps) | All Operational Amplifiers | Analog Devices,
probably the better choice of these two, whereas;
AD829 has Pin 1 and 8 for offset Null and Pin 5 as compensation, page 8 and 9 provide information regarding stability detailing where and why compensation is needed .
AD829 | High Speed, Low Noise Video Op Amp | Military/Aerospace | Other Products | Analog Devices
Old 16th March 2012, 10:43 AM   #3
AD829 is what can be used. It is fast, but it does not like poor decoupled power rails and requires some capacitors in the feedback loop. You need to check that, or it will oscillate.
Also, if at 2 kohm output impedance it has THD of -104dB, once you lower that impedance to 500 ohm you are at THD -85dB, at 250 ohm you have THD some -50dB...
TDA1541A's and AD811 opamps for sale audioman54 Swap Meet 4 24th January 2012 07:18 AM
Are these 2 motorized Pots (ALPS) "compatible" electrically-wise? jdec Solid State 1 30th March 2011 04:41 PM
AD811 Current Feedback Opamps for sale audioman54 Swap Meet 8 28th August 2009 11:12 AM
Ad811 Vs. Lm7171?? mfahimi Chip Amps 2 9th August 2009 09:32 AM
Purpose of Parallel Capacitor with AD811 I/V circuit? fastcat95 Digital Source 3 9th February 2005 05:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
