USB to I2S:  M2Tech vs XMOS vs Open-source Qnktc USB to I2S: M2Tech vs XMOS vs Open-source Qnktc - Page 6 - diyAudio
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th May 2012, 03:41 PM   #51
audiodesign is offline audiodesign  Italy
Banned
Send a message via MSN to audiodesign USB to I2S:  M2Tech vs XMOS vs Open-source Qnktc
DSD1794 Digital Attenuation: 0 dB to –120 dB,0.5 dB/Step
AD1955 On-Chip Clickless Volume Control
ES9018 On-Chip Clickless Volume Control
PCM1794 NO
PCM1796 Digital Attenuation: 0 dB to –120 dB,0.5 dB/Step
PCM1792 Digital Attenuation: 0 dB to –120 dB,0.5 dB/Step
Old 21st May 2012, 02:14 PM   #52
palmito is offline palmito  United States
palmito's Avatar
Do know when, if, the "Hybrid Output Stage 2" pcb from the "USB DAC 2 - Hi-Resolution System" will be available for sale? Thanks.
Old 21st May 2012, 04:53 PM   #53
Banned
Very soon, I am waiting in the next weeks the first pcb to test it
Old 31st May 2012, 12:34 PM   #54
UnixMan is offline UnixMan  Italy
UnixMan's Avatar
Originally Posted by audiodesign View Post
The volume use the special DAC function of the new DAC chips so no lost in resolution and no changes on on the analog signal
are you sure? how does those functions works?
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 1st June 2012, 08:22 AM   #55
fralippo is offline fralippo  Italy
Another USB to I2S board that might be interesting to compare is the exD audio, that also has the interesting feature to output LJ24 signals, very useful for a direct connection to the PCM1704 DACs. Do someone have informations on it?
Old 20th December 2012, 06:27 AM   #56
gana is offline gana  South Korea
Default Hello
Originally Posted by RayCtech View Post
I forgot to mention the USB -> I2S device I am currently using so the units I am using that are worth mentioning are: Light Harmonic Titan USB -> I2S, M2Tech USB -> I2S, QNKTC / Audio Widget USB -> I2S and exaU2I USB -> I2S...
Hello i started to test and translate i2s to TDM but i have no experience but still trying harder.. i red many of papers that how i2s works but no clear small examples for programming on c or c++. first i want to have little example that how to pragramming i2s and want to test my own source of kit based on XMOS with appropriate software.
My kit is USB AUDIO Multi Channel kit. i lost much time i want it step by step but its is too late to do that because i have few weeks to finish my project.
May it stupid questions for you but i couldnt find such a example and software yet. Any one advice or lead me would be appreciated.. thanks
USB to I2S:  M2Tech vs XMOS vs Open-source QnktcHide this!Advertise here!
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3142 Yesterday 09:19 PM
Open-source USB interface: Audio Widget borges Digital Source 2378 19th June 2017 11:05 AM
24 channels USB to I2S interface (with Source codes, ASIO/VHDL/Schematic) KOON3876 Digital Line Level 79 21st September 2016 01:06 AM
XMOS Async USB interface (UAC 2.0) dwk123 Swap Meet 1 16th August 2011 04:01 AM
FS: XMOS USB interface/dac ultrafi Swap Meet 2 27th May 2011 07:32 PM
Copyright ©1999-2017 diyAudio
