| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I am testing these 3 USB-I2S interfaces:
- M2Tech module by AckoDAC (https://sites.google.com/site/ackodac/home) - XMOS by Lucian (XMOS-based Asynchronous USB to I2S interface) - Open Source by Qnktc (Q N K T C) All are asynchronous USB Audio device using two quartz precision oscillators to clock source for output data stream with a very low jitter. I have tested these interfaces connected at the same DAC chip and there are many differences in the listen test. Last edited by audiodesign; 15th March 2012 at 03:51 PM. |
#2 |
Here an example of the test environment
http://www.audiodesignguide.com/HiRe.../WM8740sch.jpg Now I have left the WM8740 because I have found a bad sound with some new production chips. The my choice now is the AD1955 with active I/V and Lundahl transformers. I am testing some configurations to use the AD1955 with passive I/V. |
#3 | |
I have M2Tech USB -> I2S, QNKTC / Audio Widget USB -> I2S, exaU2I USB -> I2S and other USB -> I2S devices... And have done my own testing so your results would be interesting
#4 |
I hope this weekend.
Two my friends with a lot of experience on music reproduction and live recordings will be present at the test. Obviously I will indicate only the best to have no problems. |
#5 |
I forgot to mention the USB -> I2S device I am currently using so the units I am using that are worth mentioning are: Light Harmonic Titan USB -> I2S, M2Tech USB -> I2S, QNKTC / Audio Widget USB -> I2S and exaU2I USB -> I2S...
#6 |
Do you have 4 interfaces ?
#7 |
Actually more than that, but I normally uses them one at a time...
I have IR remote controlled input switching so I can switch between I2S inputs and also SPDIF inputs... When comparing units I have two identical PC / Mac systems with the same music and starts a playlist on both... Then I can switch between I2S inputs and compare units
#8 |
Which is the best for you ?
#9 |
#10 |
The AD1955 DAC have current sink outputs instead of current source outputs so I am testing some configurations suggested in this document.
http://www.ti.com/general/docs/lit/g...9&fileType=pdf |
| XMOS-based Asynchronous USB to I2S interface | Lorien | Digital Source | 1717 | Today 06:10 AM |
| Open-source USB interface: Audio Widget | borges | Digital Source | 2197 | 23rd April 2013 03:28 PM |
| 24 channels USB to I2S interface (with Source codes, ASIO/VHDL/Schematic) | KOON3876 | Digital Line Level | 69 | 15th October 2012 08:54 PM |
| XMOS Async USB interface (UAC 2.0) | dwk123 | Swap Meet | 1 | 16th August 2011 04:01 AM |
| FS: XMOS USB interface/dac | ultrafi | Swap Meet | 2 | 27th May 2011 07:32 PM |
