USB to I2S: M2Tech vs XMOS vs Open-source Qnktc - Page 5 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 21st April 2012, 04:39 PM   #41
juanito is offline juanito  Europe
juanito's Avatar
Originally Posted by audiodesign View Post
I sell the M2Tech USB to I2S module by AckoDAC (https://sites.google.com/site/ackodac/home) at 80 euro + shipping
Hi, may be I'm on the wrong thread, but now I see you tested QNKTC DAC: have you had any issues with this DAC and Mac OSX?
I have this DAC. With windows and Asio plus Foobar 2000 it works perfect. But I recently bought an Imac with OSX (snow leopard) and when using this DAC with itune or VLC media player or Cog player (there is no foobar for mac), after a while I have distortion in sound. It's very strange because it works fine for a few songs and then it's a kind of electric distortion. I'm going to install a windows partition and try also. But it surprise me because I saw that OSX doesn't need any Asio drivers, it's natively. I also changed settings with Midi Application, but nothing at all goes on.
Well if you heard any thing similar with these Dac's and OSX I would appreciate much your help.
Thanks. Bye.
JOHN
Old 21st April 2012, 05:57 PM   #42
Banned
Send a message via MSN to audiodesign Send a message via Skype™ to audiodesign
Try the player used by me
Old 21st April 2012, 06:17 PM   #43
MrSlim is offline MrSlim  Canada
Thanks. Bye.
JOHN
You'd probably be better served by posting your question on this thread:
Open-source USB interface: Audio Widget
Old 27th April 2012, 12:41 AM   #44
2A3SET is offline 2A3SET  Canada
Default Passive I/V for 1955
Andrea,
Can we run AD1955 passive like this to be compliant with the datasheet? With 2K load, there should be about 400mv RMS at output.
Old 27th April 2012, 06:16 AM   #45
Banned
I have tested many configurations with AD1955 and output transformers but always I get bad results (http://www.ti.com/lit/an/slaa399/slaa399.pdf).
To get a flat frequency response and low distortion the best method is a pure resistor followed by a high impedance stage like a vacuum tube.
The 200 ohm value has been found after many test from 47 to 2Kohm.
I should receive soon the first pcb of my hybrid output stage.
USB DAC 2 - Hi-Resolution System
Qh (http://www.quanghao.com/)will sell these pcb and the complete kit at very low cost.
Old 27th April 2012, 11:50 AM   #46
Thanks Andrea, looking forward to your SEN I/V test.
Old 8th May 2012, 02:31 PM   #47
Banned
Here the controller to get data from XMOS module and configure any DAC like AD1955, DSD1794, ES9018 ....
IR remote command for the volume and mute.
M2Tech and Open-source Qnktc sold.
Old 8th May 2012, 03:05 PM   #48
Telstar is offline Telstar  Italy
The volume attenuation uses the extra 8 bits of the xmos chip?
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 8th May 2012, 03:10 PM   #49
Banned
Which bits ?
The volume use the special DAC function of the new DAC chips so no lost in resolution and no changes on on the analog signal
Old 8th May 2012, 03:30 PM   #50
Which bits ?
Nevermind then.
I didnt know also dsd1794 had a volume function.
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3127 Today 11:26 AM
Open-source USB interface: Audio Widget borges Digital Source 2378 19th June 2017 11:05 AM
24 channels USB to I2S interface (with Source codes, ASIO/VHDL/Schematic) KOON3876 Digital Line Level 79 21st September 2016 01:06 AM
XMOS Async USB interface (UAC 2.0) dwk123 Swap Meet 1 16th August 2011 04:01 AM
FS: XMOS USB interface/dac ultrafi Swap Meet 2 27th May 2011 07:32 PM
Copyright 1999-2017 diyAudio
