Whic DAC chip to use with a PMD100 filter?? Whic DAC chip to use with a PMD100 filter?? - diyAudio
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th January 2002, 07:17 PM   #1
Brussel Sprout is offline Brussel Sprout
Default Whic DAC chip to use with a PMD100 filter??
I have a Cambridge audio S700 DAC which had quite a nice tone, but not the best imaging or separation in the world. These things improve imensely after I did a bit of reclocking but now I want to change the DAC chip..
The S700 uses a CS8412 reviever, PMD100 filter and SAA7350 DAC. I like the PMD100, but the SAA7350 has seen better days, so what would be a good DAC to use in conjunction with the PMD100?? I'd like something which would require a pretty simple output stage, and sound better that the 7350 - Obviously
I was thinking of using something along the lines of a PCM1728, but another option would be for me to add a new DAC chip and use an LCaudio Zapfilter for the output stage.
Any Ideas??
Mark.
Old 25th January 2002, 09:46 PM   #2
echo is offline echo  United States
Mark,
I think you might have a problem interfacing a delta-sigma dac like the PCM1728 dac with the PMD100 filter. All of the BB delta-sigma (bitstream-type) dacs, as well as those from Crystal incorporate digital filters internally (to the best of my knowledge...) I would suggest looking at a sign-magnitude (multibit-type) dac instead; BB has a few that would work great for your application. The PCM1704 is their latest and greatest, and will accept 20 or 24 bit data (the PMD100 outputs 20bit, right?) but is only available in a surface-mount package. For digital, this is clearly a benefit, but can be more difficult and tedious to work with. The PCM1702 is a very similar 20bit dac in a DIP package. I would probably choose the PCM63 20bit dac (also in a DIP package), if you can find a couple- it was just recently discontinued by BB. This chip was very popular in commercial dacs with the PMD100 filter, and is still regarded as one of the best chips made (it is only a bit 'outdated' because it will not accept 24bit data, which the PMD100 does not output anyway.)
Unfortunately, all of these dacs output only current, so the output stage may be a bit more complicated than with a dac which outputs voltage, but if you opt for the Zapfilter, that should not be an issue. Otherwise, all you need to add is a simple I/V stage- you can find examples on the Burr-Brown datasheets for the dac chips mentioned above.
Hope this helps, and good luck with your project!
-Mark
Old 26th January 2002, 01:05 AM   #3
wildmonkeysects is offline wildmonkeysects
wildmonkeysects's Avatar
Default More on PMD 100 interface
I second the emotion about BB 63, although now a classic, it is PFG.
Up the bypass caps to internal nodes, ref, offset, etc to much larger values.
As to I/V, I would strongly suggest going passive, or cascoded passive. My favorite is a "looped cascode" feeding a transformer, link below, which is quite a step above the standard opamp I/V shown in databooks.
http://www.AudioAsylum.com/audio/twe...ges/36482.html
One can use the above circuit with a bipolar iout DAC such as the BB 1700/1702/1704 or Signetics 1545, by adding a high impedance current source larger than the peak DAC output current to bias the cascode.
[The BB1700 is a dual 18 bit DAC, surprisingly good sounding.] Also, the PMD100 will put out 24 bits, but only with dither disabled.
Reclocking is a very good thing, with a few subtlties here: One cannot register/reclock the bitclock and data lines with a 256fs clock, so the BB 1700/1702/1704, which updates iout on a rising edge of bit_clock after a falling edge of latch_enable, preclude(s) true reclocking at the DAC unless one uses a 512fs clock and divides down to feed the transport.
One can reclock at the input of the PMD 100, where the data is still 1fs, with audible benefits. But is still best to reclock the relevant signal line at the DAC, so the BB63 takes the cake on that one: iout is updated on the negative edge of latch_enable allowing reclocking with a 256fs clock.
Also also, the 8412 loop filter is happier with component values other than the standard databook ones: try 0.22uf and 475 or 499 ohms with a 3300pF cap added from filt pin to ground.
Enjoy...
Old 26th January 2002, 07:04 AM   #4
rfbrw is offline rfbrw
wildmonkeysects wrote
"One cannot register/reclock the bitclock and data lines with a 256fs clock"
And why not ?
rfbrw.
Old 26th January 2002, 10:26 AM   #5
Carl Ekblom is offline Carl Ekblom
The Wolfson WM8740 (www.wolfsonmicro.com) accept PMD100 filter by bypassing its own digital filters. It will then be running in 8fs mode and it has differential voltage outputs.
Old 26th January 2002, 09:07 PM   #6
ftorres is offline ftorres
ftorres's Avatar
And why not ?
rfbrw.
IMHO, it would be difficult to register/reclock the bitclock @ 256fs with a master clock @ 256fs, but maybe I'm wrong....
François
"Learning French is trivial: the word for horse is cheval, and everything else follows in the same way."
Old 26th January 2002, 11:06 PM   #7
At 256 fs there are 4 Mclk cycles for every Sclk/Bclk cycle. So long as the Mclk edge occurs at the right moment in relation to the Sclk, data will be transferred from the D input to the Q output.
rfbrw
Old 27th January 2002, 03:32 AM   #8
Dave is offline Dave  New Zealand
There is no reason why you can't reclock a bit clock running at 256fs with a low jitter 256fs Master clock. You just run the data, bit clock and word clock through some D flip flops which are clocked with the 256fs Master Clock.
The critical thing is to watch the timing at the D flip flops clock in relation to the data inputs.
To get around this I was thinking about using a small FIFO say 16 words by 4 bits in place of the D flip flop. See the "Jitter in DAC" thread for more info on this.
I would say that any of the PCM63/1702/1704 would be fine to use with the PMD100.
Although I have never heard the zap filter I think its a nice design and would go very well with any of these DAC chips. Or you could just build a similar output stage yourself - It will probably work out much cheaper.
What about going the fully balanced route?
Old 28th January 2002, 02:28 PM   #9
Hi everybody,
Thanks for all the ideas!! I think I'll go for either the pcm1704 or the pcm63 (most probably the '63) I had actually been considering something with a transformer output, just out of curiosity, so I might give it a go..
I've also been toying with the idea of building an integrated amplifier with a transformer attenuator - perhaps I could do away with the output transformer and end-up with an integrated DAC-Amp?? Hmm I must think about this. Anybody got any opinions??
Mark.
Old 28th January 2002, 02:49 PM   #10
ftorres's Avatar
Question I surely miss something ...
Excuse me Sirs, but there's something I don't understand - I surely miss something obvious. How can you sample a signal at the sampling frequency ?
François
Whic DAC chip to use with a PMD100 filter??Hide this!Advertise here!
How to Control Dither on PMD100 Chip? fastcat95 Digital Source 1 1st September 2007 11:36 PM
5th order filter chip Russ White Chip Amps 8 9th June 2005 04:19 PM
SAA7220P/B to PMD100 HDCD filter - possible? Lenin Digital Source 17 4th June 2004 03:32 PM
WTB SAA7220 Filter Chip nelsonian Swap Meet 2 26th July 2003 03:46 PM
where can i buy pmd100 or some digital filter from npc ? takashi Digital Source 0 23rd February 2003 04:09 AM
Copyright ©1999-2017 diyAudio
