Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Whic DAC chip to use with a PMD100 filter??
Old 28th January 2002, 07:53 PM   #11
Dave is offline Dave  New Zealand
Sorry, my mistake - the 256fs master clock is not used to reclock the bit clock - it is used as the bit clock.
Old 28th January 2002, 08:02 PM   #12
It also important to note that the timing of the master clock in relation to the data is important so that the setup (and possibly the hold time) of the flip flop remain correct.
Also note that this is only required by the PCM63 as they require a low jitter Word Clock. The PCM1704 on the other hand requires a low jitter bit clock and if the above timing conditions are met then it should be possible to just connect the master clock straight into the bit clock pin and leave out the f/fs altogether.
Old 29th January 2002, 12:04 AM   #13
wildmonkeysects is offline wildmonkeysects
wildmonkeysects's Avatar
Default More on DF output timing
Yikes, mea culpa for not posting more details along with such a seemlingly broad statement. Was typing in a hurry as the day job keeps getting in the way of fun...
The PMD100 when in standalone mode, as with many DFs from that era, divides each 8fs output frame into 32 slices. Each frame will be filled with 16, 18, 20 or 24 bit clock pulses corresponding with number of output bits selected. The bitclock and data lines are zero stuffed after the appropriate number of bits. Deglitch goes positive 2 slices prior to bitclock/data cycles, and latch_enable goes negative one slice prior. The idea is for the critical conversion event to happen after a relative period of bit silence. Less uncertainty of "when" if everything has settled down a bit [pun time]. This works for the BB61/63, Analog Devices ladder DAC chips, and Ultra Analog modules. Does not work with BB1700/1702/1704, which convert on a positive edge of the bitclock after a negative edge of the latch_enable. Regardless, the timing of bitclock is, alas, 8 x 32 or 256fs as in the diagram from ftorres, so one would need at least a 512fs clock with correct setup/hold times to register/reclock the bitclock; and feeding a continuous clock in place of bitclock would not work, unless one was extremely lucky...maybe with 16 bit output data, so that every other sample would be zero...
One could also try asynchronous reclocking, with a 1024fs or higher clock, like 45 MHz or higher. Seems a bit whacky at first, but I would take Elso's word that it can be made to work. Probably better for 1fs non-oversampling apps.
The PMD100 does have separate core and i/o power/ground pins for a reason, to provide a lower jitter feed directly to the DAC; so if one is careful, one can register/reclock at the input of the PMD100, use separate, clean, well bypassed core and i/o supplies, and feed directly to BB1700/1702/1704. The bitclock should be short and direct for fast well defined edges, but one can experiment padding/damping the latch_enable and data lines with a 100 ohm to 1kohm series resistor.
I generally prefer sonics with dither set on, and gain scaling set analog or external with no actual scaling.
I would strongly suggest trying a transformer i/v, either passive like the Sowter 8347, or cascoded with a 1:1 SE interstage xfmr like something from Lundahl, Sowter, Audio Note.
The feedback I get from private emails is that jitter reduction, passive i/v, and clean power supplies have more of a positive effect on the sonics than the particular choice of DAC chip or module. The old adage, not what, how. But, I still like the 63...
A transformer atttenuator, such as the Sowter 9335 is a waaaay kewl thing; catch is that it does not like any DC in the primary, so feeding it directly from the cascoded DAC current is not quite the best idea. It might be ok with the 1 mA or so from the BB63, but really needs either an xfmr or a cap to block the DC. Any other reasonably priced sources of such a device that will tolerate a mA or so primary DC?
Enjoy...
Old 29th January 2002, 12:26 AM   #14
I did not realise the PMD100 output its bit clock in bursts (like the SM5847) I thought it was continuous like the DF1704/1706.
This would then require a 512fs clock which is getting pretty fast at high sampling rates.
Its interesting that the PMD100 is designed with a low jitter supply layout in mind maybe this explains the reports of better sound compared to the DF1704. The NPC chips also feature "jitter free" operation which I think enables the output to be directly clocked from the system clock. Maybe Burr-Brown need to catch up in this area.
As for I/V conversion I use a common gate MOSFET amplifier - see my site for more details.
Old 29th January 2002, 04:15 AM   #15
rfbrw is offline rfbrw
I am well aware of the idiosyncratic nature of DF1700 + 1702/63 dacs, I've had the 1702 running in 1Fs mode. It's just that the initial impression I got from wildmonkeysects post was that it was suggesting that the inability to reclock BCLK with MCLK was the general case. What with wclk, fsync, wdsync, lrclk,wsab along with sclk bclk clab all meaning the same thing and not, all at the same time it's easily done. Still, musn't grumble, it's a fair cop guv, I'll come quietly.
I don't know what specific claims are being made for "Asynchronous Reclocking" with higher and higher clock frequencies but jitter removal cannot be one of them. With so many edges validating data it does not matter when the data arrives, it will be waved through. The question is do you want a system that flags up excessive jitter or one that ignores it ?
rfbrw.
Old 2nd February 2002, 09:24 PM   #16
Spartacus is offline Spartacus  United Kingdom
Hi Brussel Sprout,
How is the S700 to work with - i.e. is there plent of space inside? Also the clock sync - does it send the actual clock signal back to the transport or just the error signal from a phase comparator as with Linn?
Wildmonkeysects, is see you recommend iron and wire for I/V conversion. It's something I've been thinking of trying, so can you tell me in what way a transformer sounds better in this application? I love percussion, and wouldn't want to sacrifice rythmic drive and impact.
Many thanks both.
Old 3rd February 2002, 05:25 PM   #17
Brussel Sprout is offline Brussel Sprout
Apartacus,
The S700 is a DAC disguised as an isolation platform with the DAC PCB sitting in the middle of the 'box'. The platform is large but quite slim so there's plenty of room around the sides of the PCB but not much room above.
The DAC outputs the actual clock signal and there's a switch on the back to select wether to use the internal oscillator (synced to the transport) or the clock from the sc8412. The clock is implemented in a bizzar, jittery way though, and benefits from a little tweaking.
-Mark.
Old 4th February 2002, 11:24 PM   #18
Default Iron for Spartacus
Yes, yes, surprisingly at first, ironically even, I found that decent iron had better PRAT than the standard textbook monolithic opamp i/v topology.
Excellent rendition of acoustic bass and drums, so jazz, world/tribal, space/trance are well served.
What I did notice is that when saturated, ie more DC in the primaries than spec, bass was lumpy and indistinct, kinda like what solid state fans dislike about less than optimal tube topologies.
Surplus UTC iron has worked well for me, but have "heard" of good results with current production Lundahl, whom I forgot to mention a couple of posts ago.
My take on the subjective end is that what we hear as "bass" response is more than steady state frequency response. When a musical event, such as a drum whack happens, low *amplitude* information over a wide frequency range gives us cues as to when, where, and why. Many active stages, with measurably good steady state response will have issues, among others, with thermal tails which will tend to blur the when, where & why. Ok for rap with thumpa thumpa thumpa, but sucks for anything with subtlety and finesse.
A big potted chunk-o-iron will be much less perturbed under dynamic, ie musical, conditions: no thermal tails, low/no supply modulation issues, free ultrasonic filtering and ground isolation.
Enjoy...
Old 5th February 2002, 06:04 PM   #19
Thanks for the replys guys.
I've got a PCM/DF1704 DAC sitting around with a fried digital filter. Grafting it onto the output of the PMD100 in the S700 looks like an option to bring it back to life.
As for transformer I/V and gain, well it really does appeal to my lazy side! Knowing little about the practical issues with transformers, I'm guessing the larger the step-up ratio, the less transparent they become. A voltage gain of say 20 that is so simple to implement and completely transparent sounds almost too good to be true.
Old 5th February 2002, 09:25 PM   #20
Default Not quite too good to be true...
BB PCM 1704s just waiting for a home? That will do just fine...
I suspect the reason we don't see/hear more trannie DACs is lack of familiarity, outside of the comfort zone. We are used to opamps being the universal elixer of audio, and in some cases add a familiar tube for flavoring; instead of starting with the proverbial clean sheet and thinking of what I call a lower entropy solution.
Two paths to iron here:
#1: Completely passive. 50 ohm to 50 K ohm UTC surplus trannies to balanced feed have worked well for me, or something like a Sowter 8347:
http://www.sowter.co.uk/specs/8347.htm
Lowish output voltage, so nogo with a "passive" preamp, but most integrateds have suficient voltage gain. Highish output impedance, so careful with interconnects. Hum pickup may be an issue with single ended. High freq rolloff may be an issue with long and/or higher capacitance interconnects.
You might try adding a 0.01 uF to 0.1 uF cap across the 25 ohm primary resistor and eliminating the secondary cap and resistor. As in the kitchen, adjust to taste. Once you get the above dialed in, is the simplest, laziest, lowest futz solution.
A technical quibble, which I believe is outweighed by the subjective performance, is that the DAC wants to see as low an impedance at the iout pin as possible, which is better accomplished with either the traditional active current summing node i/v or:
#2: Looped cascode. An addendum to this post
http://www.AudioAsylum.com/audio/twe...ges/36482.html
is that by adding a fet current source between the negative rail and the source terminal at the iout pin of several mA to bias the cascode on, one can use a bipolar current out DAC like the BB 1700/1702/1704. Although the opamp is out of the direct path, keeping the iout node at as close to zero as possible, and passing the signal current out through the drain of the cascode, it still helps to use a good one, like the BB 627. There are a number of interstage trannies to use for iron here, including:
http://www.lundahl.se/pdfs/datash/1621.pdf
Also, if you want to go full balanced, you can feed a pair of DAC chips with complementary data through a pair of looped cascodes to opposite sides of a load resistor and a balanced tranny.
Enjoy...
Whic DAC chip to use with a PMD100 filter??Hide this!Advertise here!
How to Control Dither on PMD100 Chip? fastcat95 Digital Source 1 1st September 2007 11:36 PM
5th order filter chip Russ White Chip Amps 8 9th June 2005 04:19 PM
SAA7220P/B to PMD100 HDCD filter - possible? Lenin Digital Source 17 4th June 2004 03:32 PM
WTB SAA7220 Filter Chip nelsonian Swap Meet 2 26th July 2003 03:46 PM
where can i buy pmd100 or some digital filter from npc ? takashi Digital Source 0 23rd February 2003 04:09 AM
Copyright ©1999-2017 diyAudio
