Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th April 2012, 08:20 PM   #21
Originally Posted by studiostevus View Post
This is 19+20Khz 1:1 on my NOS TDA1541a.... to be honest, I don't really know what I am (supposed to be) looking at.... enlighted me..
What I was looking for is the "grass" that is present in-band and also out-band, past the 20kHz mark.
For PCM61 the higest off-band alias apears at -84dB, for TDA1541 at -70dB (worse), for PCM1791 at some -110dB (best).
In-band I have some "grass" between the spectrum at noise floor level.
You have two huge off-band spikes mirrored around the 22.05kHz and you have a lot of in-band "grass" that rises numerous times to -80dB (don't know what the averaged total would end up). That is distortion of the original signal.
Now... What I don't know is why you don't have any beats between the fundamentals in your signal. What ADC are you using?
Old 4th April 2012, 11:26 PM   #22
I redid my measurements with different setup for the ballanced inputs (to accept unballanced signal). No change.
Loopback E-MU1820m, PCM61@0dB, PCM61@-60dB, PCM61@19+20kHz@-3dB. I still don't get what's up with the beats...
Old 4th April 2012, 11:40 PM   #23
Same measurements for TDA1541@0dB, TDA1541@-60dB, TDA1541@19+20kHz/-3dB. Same OpAmp (LM4562) as PMC61.
Old 4th April 2012, 11:48 PM   #24
And for PCM1791@0dB, PCM1791@-60dB, PCM1791@19+20kHz/-3dB.
Old 5th April 2012, 12:30 AM   #25
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
LPF... How? Where? In Arta?
In the signal. Generate a test signal, for example using Audacity etc...
Ciao T
Old 5th April 2012, 10:34 PM   #26
Bernhard's Avatar
For -60 dB, did you adjust the MSB ?
You can do it using a headphone, adjusting for most pure tone
and watching the live measurement, grass sinking in the noise floor.
Also try other pcm61 chips, you may find better ones.
Old 6th April 2012, 12:24 AM   #27
I did ajust the MSB, it did affect the 2nd harmonic the most. Maybe I can redo the adjustment now, with the better card.
I have (6) PCM61 but didn't really had time to rotate them. I was thinking to parallel them when I am bored
Measurements: When, What, How, Why D OB G Multi-Way 1658 11th January 2011 12:00 AM
are these measurements okay? eitanwaks Multi-Way 3 23rd March 2010 07:32 PM
Nearfield measurements gedlee Multi-Way 23 12th February 2010 06:14 PM
different measurements resident Tubes / Valves 4 17th April 2005 09:04 PM
Measurements? panos29 Multi-Way 3 20th April 2003 05:07 PM
Copyright ©1999-2013 diyAudio
