To get a clean sound you must have a source DAC with XLR balanced outputs
But we must know that the drives are not complementary P and N
they are composed of the same identical semiconductors
but driven by a PCM digital number in opposite phase.
So to cancel the print tone of the Digital to Analog converter
must operate a subtraction
NOT A SUM
this is possible by using a potentiometer for the adjustment of the listening volume in series with a resistor of equal value
suggest 1K
NOT A SUM
suggest 1K
NATURAL MODULATION
that PCM CONVERTER is born with wrong way
IS NOT MADE FOR AUDIO
as Law of twice denied would.
this means that the method of complementary
must be applied in a manner opposite
To qualify for compensatory timbre of the two systems
You are wrong. DAC cips are build in CMOS technology - complementary-symmetry metal–oxide–semiconductor.
And anyway, that theory canceling with P and N applies only for amplifiers final stage working in AB class. Nothing to do with DAC output that is a class D type (because of the Pulse-Modulating signal that reperesents). The digital signal is... digital, there is no "ballanced" PCM or DSD.
Read a book, something...
TEAC UD-H01 convertitore D/A con USB
The current of the PCM1796 on each of the output pins (IOUTL+, IOUTL–, IOUTR+, IOUTR–) is 4 mA p-p at 0 dB (full
Scale). Differential Current Output: 4 mA DON'T MEANS COMPLEMENTARY OUTPUT
http://www.ti.com/lit/ds/sles100a/sles100a.pdf
To find out if I'm right or wrong, just do a simple test -
a double potentiometer connected to the balanced outputs, stay around the middle of the range, the more you are close to zero is the most effective cancellation -
then turn up the gain of the amplifier with inputs unbalanced RCA
try to hear what happens to the sound:
a magical horizon suspended in midair generates sounds
no need for experiments, its pretty basic electronics that pin 1 is for shield/chassis not signal ground. if you need to connect an RCA output/input to a balanced input/output, use an instrumentation amp or transformer, which ever is suitable, dont try and make a magic cable do it
- Digital Source
- THE TRUE BALANCED SOURCE
