Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Philips CD931: good or not?
Old 17th November 2003, 04:40 PM   #41
stefanobilliani is offline stefanobilliani  Italy
Oh , Thanks a lot
Old 18th November 2003, 05:21 PM   #42
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
Just to let you know: at last my CD931 arrived!!
Now it's time to play with it
Cheers
Andrea
Old 18th November 2003, 06:36 PM   #43
tbla is offline tbla
thats exactly what she said 10 minuts agooooooooooooo moon river.....
Old 3rd March 2008, 09:22 PM   #44
PA0SU is offline PA0SU  Netherlands
PA0SU's Avatar
Default CDM4 in the CD624
Reading all this about updating CD-players, I have very good results with the old and cheap CD624! The CDM4 is very good, reads all there is. The main board is well designed and the connections for the I2S behind the SAA 7310 are concentrated on a (not mounted) plug. The I2S has the Philips standard: 'justified left with one bit delay'.
The most nice thing is: it has a compete large separate section to build in the new back end and its power supply!
Systems that assume to know too much are more a hindrance than a help.
(Software Tools)
Old 3rd March 2008, 09:22 PM   #45
PA0SU's Avatar
Default I2S and the digi-filter SM5847AF
The SAA7310 in my CD624 offers I2S with 'left justified with one bit delay' as I stated before.
For the back end I try to use a part of Guido Tent cs. tube DAC. This DAC is equiped with the SM5847AF digital filter which only accepts I2S 'justified right'.
I moved the data 15 bits to the right with a shift register, but is does not work! It could be that the clock from the SAA7310 should be inverted before clocking the shift register.
I think the DACs are missing the sigh-bit, so....
Any suggestions?
(Software Tools)
Old 4th March 2008, 09:09 PM   #46
philpoole is offline philpoole  England
The circuit posted in the first post of this thread...
http://www.diyaudio.com/forums/showt...ghlight=sm5840
...shows how the saa7310 is interfaced to the sm5840 in a CD930, using shift registers for format conversion. Not sure if it helps.
Old 5th March 2008, 01:39 PM   #47
PA0SU's Avatar
Please give me the complete 'address'. I can't find it!
(Software Tools)
Old 5th March 2008, 01:43 PM   #48
http://www.diyaudio.com/forums/showt...133&highlight=
Sorry, not sure what happened there.
edit.. tried the old one and that worked for me as well. You are just clicking on the link aren't you?
If you're still stuck, search for sm5840, and click on the thread 'confusion over I2S buffering'.
Old 5th March 2008, 02:08 PM   #49
PA0SU's Avatar
OK!
But I'm more dumb than you on this subject. Please look there for some questions of my side.......
(Software Tools)
Old 6th March 2008, 07:48 PM   #50
PA0SU's Avatar
Where can I find the schema/service doc of the CD930?
ESL + MFB = the best of 2 worlds ==> www.by-rutgers.nl
(Software Tools)
Philips CD931: good or not?Hide this!Advertise here!
FS: Philips CD931 with internal TDA1541A DAC & JFET STAGE cartman Swap Meet 1 9th April 2011 06:49 AM
Philips CD930/CD931/CD940 service manual Bricolo Digital Source 33 15th February 2009 09:11 AM
philips cd931,cdm9 problems. kaulagalvis Digital Source 2 11th November 2007 08:19 AM
Philips CD930 and CD931 whats the diff? hacknet Digital Source 15 15th June 2004 01:56 PM
FS: Philips CD931 (Europe only) FrancoB Swap Meet 2 13th April 2004 02:41 PM
Copyright ©1999-2017 diyAudio
