Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
upgrade CD output caps
Old 15th February 2012, 06:02 AM   #1
ngovanhinh is offline ngovanhinh  Viet Nam
Default upgrade CD output caps
I want to replace my CD's output caps (47uF/50V) with film MKP ones. Could anyone help me what value is suitable for these caps. Will small value of film caps give the sound less bass?
Old 15th February 2012, 06:51 AM   #2
SoNic_real_one is offline SoNic_real_one  United States
Yes.
Paralel smaller ones with what you have.
Old 15th February 2012, 08:23 AM   #3
sharpi31 is offline sharpi31  United Kingdom
You need to confirm the total load on the output to predict how changes to cap value will impact on bass. To do this find the input impedance of the amplifier (or whatever your connecting to) and also the value of any resistor to ground after the output coupling cap in the CD player (often there is a 100K or similar resistor after the cap to drain charge down).
Once you know the total load you can use this online calculator to predict the -3dB point of a given capacitor value: Coupling Capacitor Calculator by V-Cap
Aim for a cap big enough to reduce the -3dB frequency below 2Hz. Increasing the cap value beyond that won't make any audible difference to bass response.
Unless you have a very low input impedance at your amplifier I suspect that a cap value of <10uF will be fine, allowing you to use one film cap (rather than a small film cap bypassing a bigger electrolytic).
Old 15th February 2012, 08:26 AM   #4
Mooly's Avatar
What's the player ?
If the overall cap value is smaller than 47uF then bass is less all other things being equal (meaning the impedance of whatever is connected to the output of the player).
Old 15th February 2012, 05:30 PM   #5
stephensank is offline stephensank  United States
For heaven's sake, just take a DC voltage reading on both sides of each cap with player running. If you have 0V DC within 100mV or so +/-, then NO CAP is the best sounding solution, i.e., just replace each cap with a jumper wire.
Old 15th February 2012, 09:47 PM   #6
That makes zero practical difference. I tested it with persons that where convinced that can "hear" the capacitors (parallel like said above) and they failed to go above 50% guesses.
I used four wires with a dual switch to test.
Old 16th February 2012, 12:54 AM   #7
Dear sharpi31
The input impedance of the amplifier is 47Kohm and if I choose -3db corner frequency of 2Hz as recommended in Vcap article, then the optimal cap value should be 1.69uF. Is that right? And if so I would choose 1.8uF for my caps?
Old 16th February 2012, 12:57 AM   #8
On Hiatus
SY's Avatar
That sounds right. A 47u film cap will be quite large and both its size and the necessity of long leads may well actually degrade the player's performance. A 2.2uF cap should be adequate if you have a 47k load.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 16th February 2012, 01:15 AM   #9
Maybe I'll get 2.2uF caps for replacement as you suggested. Thanks
Old 6th August 2012, 09:45 AM   #10
I have chosen 2.2 mundorf mkp as replacement and the result is better. The question is why did the manufacture choose the 47uF electrolytic capacitors for output not 2.2uf electrolytic ones or 2.2uf film ones for better? By the way, my cd player is Kenwood dp-7050
upgrade CD output capsHide this!Advertise here!
Upgrade output Shanling CD-S100 MkII CeeVee Digital Source 233 3rd March 2012 08:05 PM
Parallel output caps in cd players 210 Digital Source 0 28th January 2011 03:04 PM
CD player output caps - calculations reaction Digital Source 5 28th May 2005 03:37 PM
which caps to upgrade in Proac clone? wilsonj Multi-Way 0 28th July 2003 11:26 PM
