Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
TAS1020B-based Asynchronous USB to I2S/SPDIF converter 24bit/96kHz
Old 14th November 2012, 01:00 PM   #81
Neteagle is offline Neteagle  France
Good job, very nice board !
I'm interested in buying one if possible too :-)
if I like it, I just do it !
Old 15th November 2012, 01:57 AM   #82
maczrool is offline maczrool
Any thoughts on offering just the firmware or a preprogrammed EEPROM for those of us that might want to build our own hardware?
Old 15th December 2012, 12:05 PM   #83
crobbins5421 is offline crobbins5421  United States
Default Wonderful!
I purchased one of the original (prototype?) boards with USB isolator, external clocks, and I2S output. After an extended work travel period, I was finally able to refocus time on getting the TAS board integrated in my system. I utilize a TDA1541 NOS DAC chip. The JarekC board is externally powered by a 3.3V Salas shunt.
I initially had some noise that was due to a faulty ground (my mistake). Once that was fixed, I was prepared to let the board settle in for a few hundred hours. I didn't need to....the sound was immediately wonnderful.
One of my problems with most USB converters is that they sound "thin". There's no "weight" to the music. This doesn't mean that the sound is overly rich or syrupy. The musicans and instruments each occupy their own space in the black background. The upper frequencies are glare free and the bass is outstanding.
I wanted to thank JarekC again for returning my emails and being patient with my many questions. I cannot wait to hear the new version.....
Bravo!
Old 18th December 2012, 07:02 AM   #84
arizzi is offline arizzi  Italy
Default Interested in buying
Hello Jarec,
I've added my name in the list for buying from next batch. Have you any idea when will it be available?
Andrea
Old 18th December 2012, 01:11 PM   #85
JarekC is offline JarekC  Poland
Hi All,
Sorry for the long absence at forum but I had some problems with health.
I had to spend several days in hospital.
But I'm back.
>crobbins5421
Thank you for the kind words.
New version of USB-I2S is ready. All works fine.
On PCB is a small error in the description of I2S connectors. (corected by label)
Tomorrow I will post information about avaliable versions and costs.
Changes compared to the previous version:
-galvanic isolation on PCB (ADUM3160 + LDO)
-shorter track for Master Clock signal (from XOs to TAS1020B)
-elimination of the multiplexer in the Master Clock signal path
-sampling rate signaling with 4 LEDs (each has its own LED)
-series termination resistors on the I2S bus lines
-22.5792/24.5760MHz generators + LDO can be mounted on the PCB, or connected via connector
-two modes: 16 bit (32bitframe-16bit data) and 24 bit (32 bit frame-24bit data)
(I can make special only 16 bit version 16bit frame-16bit data for old 16bit DACs)
-derived power to the I2S connector, ability to supply DAC
-smaller dimensions, only 67mm x 30mm
-4 mounting holes
Best regards
JarekC
Old 20th December 2012, 01:13 PM   #86
At this moment I have only 10 PCBs (3-4 are now reserved).
A I can build two version of USB-I2S converter:
Version A:
- TAS1020B aynchronous mode I2S output 24bit (32/24 frame ) & 16bit (32/16 frame)
- Fs 44.1kHz, 48kHz, 88.2kHz, 96kHz
- MCLK = 256 Fs
- low noise LDOs (2X LP2985)
- USB Connector Type B
- I2S Connector 2x5 Pin (raster 2.54mm) (3.3V HCMOS Levels)
- Low jitter generators 22.5792MHz/24.576MHz
- powered from USB or external supply (jumper)
- control LED + header (1x6Pin ) for Fs LEDs
- native drivers for Windows, MAC OS, Linux (UAC1.0)
- gold plated PCB
Version B:
- Version A + galvanic separation (ADUM3160)
- USB side powered from USB BUS, TAS side powered from external supply
Version A costs 220 PLN (Polish Zloty) its about 68$/52Euro
Version B costs 278 PLN (Polish Zloty) its about 87$/66Euro
Shipping cost is 19 PLN about 6$ (Registered Mail Polish Post)
PapPal Fee is 4%
Best regards
JarekC
Old 20th December 2012, 01:19 PM   #87
Hello, I'm ok to buy a Version A, I sent you PM. Tell me if it is ok and in stock...
Old 21st December 2012, 05:56 AM   #88
Martin12341 is offline Martin12341  Germany
Hi Jarek,
I want to order Version B, messages sent to you. (Second PM was a mistake).
Martin
Old 9th January 2013, 05:43 PM   #89
torusJKL is offline torusJKL  Switzerland
Hi Jarek
I'm very interested in the SPDIF version.
It should work with a Debian GNU/Linux computer. As far as I understood this is supported but I just want to be sure.
Do you have any idea when you will be able to get the parts?
You mentioned an aluminium case. Where you able to design one?
How about an HDMI version for DTS-MA and Dolby TrueHD passthrough?
Old 16th January 2013, 09:41 AM   #90
Aditional information:
- connection scheme of external components (correct I2S pinout)
- device scheme for people who want to modify supply or another part of the converter
If anybody interested I still have 2connverters for sale , version A or B.
SPDIF version still in design.
Best regards
JarekC
TAS1020B-based Asynchronous USB to I2S/SPDIF converter 24bit/96kHzHide this!Advertise here!
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3172 17th January 2018 11:26 AM
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 03:55 PM
Native 24bit 96k USB to Spdif I2S Converter Module DAC julcat Digital Line Level 11 3rd September 2010 01:59 PM
FS:USB-SPDIF/I2S Converter $45 bbp Swap Meet 13 7th February 2010 01:55 AM
USB to 24bit/96KHz edpgc Digital Source 8 21st November 2004 02:40 PM
