Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd August 2012, 09:45 AM   #71
JarekC is offline JarekC  Poland
I going on holiday !
New information about the project after my return.
Best regards
JarekC
Old 3rd August 2012, 10:08 AM   #72
Have fun JarekC
Old 7th September 2012, 02:26 PM   #73
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Have fun..
Regards Åke
Old 16th October 2012, 06:36 AM   #74
Hello,
I'm also interested in this, SPDIF version, but have no great experience with diy. Is there a list somewhere of the steps needed to have it up and running?
Thanks,
Gio
Old 19th October 2012, 05:47 PM   #75
Originally Posted by gior View Post
Hello,
Thanks,
Gio
Converter is ready to use.
For all systems Windows , Mac Os, Linux it uses native drivers.
So you connect converter to PC and it should be recognized automatically.
In system it will appear as "Audio device"/"USB->SPDIF V1.0x"
Sorry but at this moment SPDIF version is sold out.
New PCB version soon.
JarekC
Old 19th October 2012, 06:11 PM   #76
Hi all,
New PCB for USB-I2S version is READY.
Yesterday I sent files to PCB factory, so test pices should be on my desk for 10 days.
Connectors on PCB:
USB - USB bus (type B)
I2S - I2S bus (IDC 2x5pins raster 2.54mm)
POWER - input for external power supply (2x1 pin raster 2.54mm)
JP3 - jumper for selecting USB Bus/External supply, instead jumper you can connect switch(3x1 pin rasetr 1.27mm)
LED - Power LED and Fs LEDs (each Fs has own LED) (6x1pin raster 1.27mm)
J3 -input for external master clock (4x1 pin raster 2.54mm)
Changes compared to the previous version:
-galvanic isolation on PCB (ADUM3160 + LDO)
-shorter track for Master Clock signal (from Xo to TAS1020B)
-elimination of the multiplexer in the Master Clock signal path
-sampling rate signaling with 4 LEDs (each has its own LED)
-series termination resistors on the I2S bus lines
-22.5792/24.5760MHz generators + LDO can be mounted on the PCB, or connected via J3 connector
-additional 16-bit modes for connecting 16-bit DACs such as TDA1541A, TDA1543, etc. (during testing)
-AC-3 passing through mode (during testing)
-derived power to the I2S connector, ability to supply DAC
-smaller dimensions, only 67mm x 30mm
-4 mounting holes
Best regards
JarekC
Old 24th October 2012, 02:39 AM   #77
ppap64 is offline ppap64  Canada
Awesome news and welcome back !!!
Whenever you're ready, I'm in for a couple boards
Old 25th October 2012, 10:37 AM   #78
Hi Jarek,
this board looks very good to me, excactly what I need. I would like to order one when you are ready.
Martin
Martin
Old 12th November 2012, 07:58 PM   #79
SteB is offline SteB  England
Looks good, i'm interested also
Old 14th November 2012, 11:27 AM   #80
Hi All,
I recieved first prototype PCBs (new I2S version, 10pcs, gold plated) and TAS1020B
Tomorrow I will start assembling.
Best regards
JarekC
XMOS-based Asynchronous USB to I2S interface Lorien Digital Source 1724 22nd May 2013 06:50 PM
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
Native 24bit 96k USB to Spdif I2S Converter Module DAC julcat Digital Line Level 11 3rd September 2010 12:59 PM
FS:USB-SPDIF/I2S Converter $45 bbp Swap Meet 13 7th February 2010 12:55 AM
USB to 24bit/96KHz edpgc Digital Source 8 21st November 2004 01:40 PM
Copyright ©1999-2013 diyAudio
