| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#41 |
I got a question how to connect the USB-I2S converter to DAC Lampucera Maxi (DIR9001,CS8421, PCM1798). I think I think the best solution is to use multiplexer and connect I2S signals before CS8421. Simply remove R20,R21,R22 and connect according to the diagram. 74LVX157 can be replaced by signal relay or mechanical switch. I have plans to redesin PCB: -separate LED for each FS -add multiplexer for I2S signal -smaller PCB for USB-I2S version Best Regards JarekC |
#42 |
Hello JarekC,
I'm very interested in your board and I'd like to know when the new version of Usb to I2s will be available. I think that a separate external PSU for TAS and Oscillators would be perfect. The implementation of the galvanic isolation in your opinion is really suggested? Have nice day. Thanks Guglielmo Italy |
#43 | |
If anyones needs smaller PCB (I2S version) it is possible to cat off PCB (details in the picture). In the current version each module has own LDO (Low noise LP2985) -first for TAS1020B and WM8804 (digital part) -second for WM8804 (analog part) -third for oscillators Analog and digital parts of TAS1020B are additionaly separate by ferrite bead. I think that main improvement is after adding oscillators and powering converter from external PSU. I have plans to start redesign PCB in next week. Best regards JarekC |
#44 |
Before new PCB project, some information about AES/EBBU output.
Current PCB is ready to add AES/EBU output. You need add: - integrated circuit DS26LV31 SMD (U12) - resistor 110Ohm SMD0805 (R14) - capacitor 100nF SMD0805 (C32) - transformer PE65612 (TR2) - XLR connector Components R14,C32,U12 mounted at BOTTOM side (RED), a TR2 at TOP side (BLUE). XLR conected to J6 Details are shown in the drawings and schematic. (Testetd by several DIY users) DS26LV31 can be replaced by ST3485 (simple modification on PCB). JarekC |
#45 |
Hi All,
I received a well-packaged USB to I2S board with external oscillators from Jarek last week. The TAS1020B board is nicely done amd replaced a PCM2707 board in my setup. As others have said, Jarek's board easily outclasses it. No comparison, really. I'm using the TAS1020B board to feed a PCM1794A-based DAC. I/V is 18ohm resistors & 500:15k step-up transformer. Thanks again, Jarek, for making this piece of kit available. Regards, John |
#46 |
Hello JarekC,
what about the new usb to I2s board? Ciao guglielmo W Italy
#47 |
I need a little more time to complete a PCB project. I have two major projects to complete in my work so I haven't free time for DIY Regards JarekC |
#48 |
Any new?
Ciao Guglielmo |
#49 |
I am also interested in buying ready made pcb of USB to SPDIF when available.
Thank you - Richard Marsh USA |
#50 |
I'm interested in a USB to I2S device when available.
Thank you Phil |
| XMOS-based Asynchronous USB to I2S interface | Lorien | Digital Source | 1798 | Yesterday 08:44 PM |
| HLLY USB SPDIF/ I2S CONVERTER | kp93300 | Digital Source | 12 | 29th January 2012 02:55 PM |
| Native 24bit 96k USB to Spdif I2S Converter Module DAC | julcat | Digital Line Level | 11 | 3rd September 2010 12:59 PM |
| FS:USB-SPDIF/I2S Converter $45 | bbp | Swap Meet | 13 | 7th February 2010 12:55 AM |
| USB to 24bit/96KHz | edpgc | Digital Source | 8 | 21st November 2004 01:40 PM |
