Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 26th January 2013, 04:55 PM   #91
I am interested. Do you still have one available?
Old 12th February 2013, 08:46 PM   #92
Hello Jarek,
i have just finished my little DAC project with your USB/I2S converter and it is working very good. I am running a headless Intel D510MO-Board with Voyage MPD. The D/A-Converter is a PCM1794 COD board from twistedpearaudio.com, I/V-conversion is done by 33 Ohm resistors and little transformers from South Korea. I am very satisfied with this solution. Good work Jarek!
Have a nice day
Martin
Martin
Old 14th February 2013, 02:09 PM   #93
JarekC is offline JarekC  Poland
It's nice to see that the converter works, and the user is satisfied.
New version od USB-S/PDIF is comming.
Best regards
JarekC
Old 21st February 2013, 09:20 AM   #94
New version of USB-SPDIF PCB is finished.
Changes compared to the previous version:
-galvanic isolation on PCB (ADUM3160 + LDO)
-shorter track for Master Clock signal (from XOs to TAS1020B)
-elimination of the multiplexer in the Master Clock signal path
-sampling rate signaling with 4 LEDs (each has its own LED)
-series termination resistors on the I2S bus lines
-22.5792/24.5760MHz generators + LDO can be mounted on the PCB, or connected via connector
-two modes: 16 bit (32bitframe-16bit data) and 24 bit (32 bit frame-24bit data)
-LEDs and power switch on the front side , connector on the back side
-4 mounting holes
- S/PDIF Output: COAX, TOSLINK, AES/EBU
First prototypes PCBs (5pcs) in production.
A also ordered next batch (10 pcs) of PCB for USB-I2S converter.
If any one is interested in it will be available in early March.
In attachment pictures of PCB, both versions USB-I2S and USB-S/PDIF.
Best regards
JarekC
Old 21st February 2013, 10:49 AM   #95
regal is offline regal  United States
I can't find a power adapter plug that fits with the first version does anyon know the size of the male pin for the power supply jack?
Old 21st February 2013, 11:07 AM   #96
Old version (6107 PCB): Power Plug 5.5mm/2.1mm
Newversion (6117 PCB): Power Plug 4.5mm/1.3mm
For example:
Connectors, Interconnects | Barrel - Power Connectors | DigiKey
Best regards,
JarekC
Old 21st February 2013, 04:05 PM   #97
I am interested in the USB-I2S version. How do I order it?
Old 21st February 2013, 09:25 PM   #98
acccruz is offline acccruz  Portugal
Hi:
Depending the final price I´m also interested in the USB-I2S version.
Thank you,
Antonio
Old 21st February 2013, 09:34 PM   #99
Informtion about costs (USB-I2S version) is in this thread (#86 20.20.2012)
USB-I2S converters will be available in early March (5-6).
Best regards
JarekC
Old 1st March 2013, 01:09 PM   #100
Today I recievd PCBs for new version of USB-S/PDIF and USB-I2S converters.
Mounting and and testing begins on Monday
USB-I2S is compatible with my ES9023DAC.
ES9023 DAC + USB Asynchronous Input (TAS1020B)
Best Regards
JarekC
XMOS-based Asynchronous USB to I2S interface Lorien Digital Source 1714 11th May 2013 03:43 PM
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
Native 24bit 96k USB to Spdif I2S Converter Module DAC julcat Digital Line Level 11 3rd September 2010 12:59 PM
FS:USB-SPDIF/I2S Converter $45 bbp Swap Meet 13 7th February 2010 12:55 AM
USB to 24bit/96KHz edpgc Digital Source 8 21st November 2004 01:40 PM
Copyright ©1999-2013 diyAudio
