Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th February 2012, 09:35 AM   #1
Goetz is offline Goetz  Germany
Default Yamaha CDX-596 schematic needed for tuning
Dear All,
I'am looking for a schematic of Yamaha CDX-596 for tuning with Burson op-Amps etc., better caps, violin laquer etc.
If you have further proposal, experience to share pls let me know.
Esp. a schematic would be helpful.
Thank in advance for your help.
Have a nice day and sucessful week !
Goetz
Old 7th February 2012, 12:12 PM   #2
I have full service manual. Do you need circuit diagram only?
Suggestions after very quick glance at the circuit diagram:
1. 16.9344MHz oscillator with dedicated low noise power supply
2. AD1854 will do much better with LM4562 if you pay a bit of attention to lowering the noise and get local decoupling at OP's done semi-decent. If you get job done properly, use LM6172. DAC is Vout type, so you could try simple differential to single end transformer solution and omit all IC’s / the whole analogue stage.
3. the chip used in power supply is mediocre dual tracking type: M5290 with bad ripple rejection - you could install your own power supply regulation to obtain much better results... even with the transformer in analogue stage, it appears you’ll still need +5.6 V DC used in an analogue stage, for spindle motor & its servo control, so analogue power supply will have to stay….
Let me know if you are happy with circuit diagram only, I can extract the page and post it here on this thread for others to use / give suggestions….
Boky
Old 7th February 2012, 12:19 PM   #3
diagram
Old 7th February 2012, 01:59 PM   #4
Dear Boky,
thank you very much for your magnificient and prompt support. This player has to perform with its own DA, no external. So I have to do the best what is in there.
Thanks again for your advise !
Goetz
Yamaha A-6a schematic needed sesebe Solid State 13 17th May 2012 12:28 PM
Yamaha CDX-10000 Schematic, etc. dzungtle Digital Source 13 25th July 2010 07:25 PM
Yamaha P2500S schematic needed lumanauw Solid State 4 12th November 2008 09:19 AM
Yamaha CA-400 schematic needed Algar_emi Solid State 2 8th December 2003 11:39 AM
Yamaha cdx 993 MadMax Digital Source 3 13th May 2003 01:39 PM
Page generated in 0.08214 seconds (73.97% PHP - 26.03% MySQL) with 11 queries
